2
wifi network problem with PUBG Mobile
  1. sanchitG0001
    Cupcake Nov 3, 2018
    sanchitG0001 , Nov 3, 2018 :
    i am not able to play pubg mobile with wifi network in my (6T). game shows network error while connected to wifi and starts when connected to mobile data.
  2. Q1541247636289
    Cupcake Nov 3, 2018
  3. sanchitG0001
    Cupcake Nov 4, 2018
    sanchitG0001 , Nov 4, 2018 :
    okay thanks...i will try that
  4. G1587717092721
    Cupcake Apr 24, 2020
    G1587717092721 , Apr 24, 2020 :
    Same bro please let me know if you got any solution to that
  5. G1587717092721
  6. r.niranjenkumar
    Cupcake May 30, 2020
    r.niranjenkumar , May 30, 2020 :
    Same problem I am also facing in oneplus 6 it's perfect to play PUBG on mobile network but when I connected to Wi-Fi I am facing the problem of network error and can't load the game even if loaded with mobile data and then switched on Wi-Fi the multiplayer voice is not clear in the game
  7. Caomhin
    Marshmallow May 30, 2020
    Caomhin , via OnePlus 6T , May 30, 2020 :
    Make sure the Pubg Game has the permission to access the game in Pubg, App info, Permissions. Also check that the options within the game settings are correct.
    Also check your WiFi router settings to ensure there are no restrictions. Check your WiFi manual and see if there are settings that can be optimized for gaming.
  8. Vivek1994991
    Cupcake Jul 3, 2020
    Vivek1994991 , via OnePlus 8 Pro , Jul 3, 2020 :
    hello bro I am facing pubg mic issue on my brand new OnePlus 8pro with wifi . it works all well with mobie network.
    please suggest if u had any solution.
  9. Caomhin
    Marshmallow Jul 3, 2020
    Caomhin , via OnePlus 6T , Jul 3, 2020 :
    Vivek1994991
    please suggest if u had any solution.​
    Is it the mic on the Bluetooth headset or the mic on the phone?
  10. Vivek1994991
    Cupcake Jul 3, 2020
    the mic on any irrespective of mobile or headphones is not working on wifi it's working only when game played with mobile data .
    I have checked all permissions game runs well with wifi but only microphone doesnot work.
    please suggest
  11. Caomhin
    That's unusual, sounds like a conflict of some sort, be very hard to pin that down.
    Try reset the WiFi adapter
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth
    Might help.
  12. Vivek1994991
    Cupcake Jul 3, 2020
    thanks for update.
    wifi is no issue coz rest of game runs perfectly on wifi only mic issue exists. also other whatsapp calls and all work properly. I heard same issue from another user with OnePlus 7 from last evening only.
    you can find the issue on my thread " mic not working in pubg mobile"
    please suggest a solution.thanks
  13. Caomhin
    I was suggesting the WiFi reset because it seems there is a resource conflict. You said sound works on Mobile and not on Wifi.
    By resetting the WiFi adapter, it may resolve the conflict, no guarantee, but worth a try.
    Also contact OnePlus support directly to see if they have more information on your issue. Scroll down the page for contact and online chat details.
  14. Vivek1994991
    Cupcake Jul 3, 2020
    I have just tried ur suggestion reset my wife settings on mobile also did a reset of my wifi router rebooted the phone too still same wifi microphone issue persists :(:(
    vidhyudh likes this.
  15. vidhyudh
    Cupcake Jul 3, 2020
    vidhyudh , via OnePlus 6 , Jul 3, 2020 :
    I am facing the same problem. I have a One Plus 6 LE, I tried contacting the one plus service, but I received no response. Could someone actually give me a remedy. Thanks in advance
  16. Vivek1994991
    Cupcake Jul 3, 2020
    from when are u facing this problem??
  17. vidhyudh
    Cupcake Jul 3, 2020
  18. Vivek1994991
    Cupcake Jul 3, 2020
    same even I am facing this issue since same time also another OnePlus 7 user facing same issue from last evening
  19. vidhyudh
    Cupcake Jul 3, 2020
  20. Vivek1994991
    Cupcake Jul 3, 2020
