wifi - not obtaining ip address
  1. V1541923336317
    Cupcake Dec 27, 2018
    V1541923336317 , Dec 27, 2018 :
    hello
    My 6t has stopped obtaining WiFi.
    It's stuck on obtaining IP address.
    There are no WiFi issues as my tablet works fine on it.
    I've reset the WiFi options in settings, rebooted the phone.
    I haven't had any updates since I was connected to it yesterday.
    Why has it stopped overnight?
    Any ideas are welcome?
    I'm hoping this isn't a permanent feature.
    Adam
    McJader likes this.
  2. GuidoNervi
    Gingerbread Dec 30, 2018
    GuidoNervi , Dec 30, 2018 :
    hello,
    login into your router and check for DHCP logs to verify your phone send DHCP request and your router reply with DHCP offer and an IP address.
    cheers
    TheMystic, Tokolozi and McJader like this.
  3. V1541923336317
    Cupcake Dec 30, 2018
  4. Lisette kili
    Eclair Apr 18, 2021
    Caoimhín likes this.
  5. NaXal
    Gingerbread Apr 18, 2021
    NaXal , via OnePlus 8T , Apr 18, 2021 :
    Every device connected to a network needs an IP Address.
    There are two ways of setting an IP address for a specific connection, either you manually set the IP address for every WiFi network you connect to, or the WiFi Router / Access point automatically gives & set an IP address for your device.
    This automatic IP address distribution process is handled via a DHCP server. This feature is built into every WiFi router. So you need to log into the WiFi Router settings panel & check if DHCP server option is on or off. If it's off, then your phone or any phone or laptop trying to connect to that network can't get / obtain IP Address for internet use.
    Thanks.
    TheMystic likes this.
  6. Lisette kili
    Eclair Apr 18, 2021
    Lisette kili , Apr 18, 2021 :
    But wifi works perfect on my 2 tabletsand this error hapoens also on mobile network hapoens
  7. Bobbie63
    Marshmallow Apr 18, 2021
    Bobbie63 , Apr 18, 2021 :
    Try to reset your network adapters, settings, system, options for reset (I hope this is translated the right way), reset WiFi mobile and Bluetooth. You might have to set up you WiFi connection and Bluetooth again after this reset.
    Caoimhín and Tokolozi like this.
  8. Lisette kili
    Eclair Apr 18, 2021
  9. Bobbie63
    I saw that, have you tried what I mentioned before, the reset of the adapters?
  10. Lisette kili
    Eclair Apr 18, 2021
  11. Lisette kili
    Eclair Apr 18, 2021
    Lisette kili , via OnePlus 6 , Apr 18, 2021 :
    You mean the electricity abd internet plugs? Yes sure did it abd reboot but what with the same oriblem with mobile net work
  12. Bobbie63
    Again, have you tried what I said before?
  13. Bobbie63
    I meant this: Try to reset your network adapters, settings, system, options for reset (I hope this is translated the right way), reset WiFi mobile and Bluetooth. You might have to set up you WiFi connection and Bluetooth again after this reset.
  14. Lisette kili
    Eclair Apr 18, 2021
    How do i do all that please?
  15. Bobbie63
    Like it said
    goto settings
    Scroll down to system tap system
    Tap on option for reset (I think it’s called that way)
    Tap reset WiFi, Mobill and bluetooth
  16. Lisette kili
    Eclair Apr 18, 2021
  17. Lisette kili
    Eclair Apr 18, 2021
    Ok ill try thanks
  18. Bobbie63
    Wait is it only with google or all sites, as I see you’re posting from your phone now
    Edit
    Also is it just Chrome that's not working or don't you have internet at all?
  19. Lisette kili
    Eclair Apr 18, 2021
    Not all site
    Goigle and many ithers , in general if I enter internet wuth an App then it works🤔
  20. Bobbie63
    I guess the issue is in Chrome then. Have you lately updated Chrome?
