Wifi not really working, apps keep losing connection
  1. M0riTzx33
    Donut Sep 27, 2021
    M0riTzx33 , Sep 27, 2021 :
    Hey,
    i got my OnePlus 9 Pro a few weeks ago and I dont really get fit with it. Battery was Shit the first 2 weeks, its now way better and acceptable.
    I still have problems with apps loosing connection. When im connected to Wifi and scrolling through Instagram for example, I have to close and open the app every 2 minutes because nothing is loading anymore. My Wifi is good, speed and connection is excellent. Happens with other Wifi sources too. It drives me crazy. I cant use any app correctly as it happens with every app.
    Imagine owning a nearly 1k€ phone and have to deal with stuff like this. For that price I expected something else. Something more worked on, without stupid Bugs like this. This comes from a former OP1 owner, so I know you were able to build and maintain excellent phones.
    BERSEY DINO CIBIN X M likes this.
  2. Tokolozi
    Most Original Avatar Sep 27, 2021
    Tokolozi , Sep 27, 2021 :
    can you disable the "intelligent wifi..." in the wifi settings. This feature is quite buggy depending on your wifi setup.
    Caomhin likes this.
  3. M0riTzx33
    Donut Sep 27, 2021
    Thanks for your answer. It was turned on, but I dont think it will change anything. I dont have any access to other WIFIs here, so it cant connect to others. But I try it.
    Tokolozi likes this.
  4. Tokolozi
    Even if you have a router with both 2.4 and 5.0Ghz bands it likes to hop between the two.
    You could also try resetting your wifi adapter settings. That often helps too.
    Once I changed those on a device here it seemed to make everything better. And I have quite the complicated WiFi setup at home with mixed mesh and normal access points with a guest network.
    Caomhin likes this.
  5. M0riTzx33
    Donut Sep 27, 2021
    I tried it now for the last 2 hours. At first I thought that its better but its back to the old behaviour. I also disabled battery optimization for instagram, no change.
  6. Tokolozi
    Can you try this as well then:
    Caomhin likes this.
  7. M0riTzx33
    Donut Sep 27, 2021
    Again was working fine for half an hour and went back to buffering after 1 or 2 mins
  8. Tokolozi
    That's really strange. I suggest taking wifi logs via the community feedback option in the app and sharing them there.
    Caomhin likes this.
  9. eddyros
    Honeycomb Sep 27, 2021
    eddyros , Sep 27, 2021 :
    Does it happen with OnePlus 9 Pro only?? Have you tried using same Wifi with other device??
  10. M0riTzx33
    Donut Sep 27, 2021
    Only with my phone... My old P30 Pro works just fine. Its definetly device related
  11. Tokolozi
    Does your router have both 2.4 and 5ghz?
    Do they have different network names too (just to rule out some stuff)
    Can you try for a short period using a guest network on the op9 to see if the issue persists?
    Caomhin and eddyros like this.
  12. eddyros
    eddyros , via OnePlus 8T , Sep 27, 2021 :
    That's the point, sometimes the two wifi network have same try to enter into wifi router settings anche change one of them
  13. M0riTzx33
    Donut Sep 28, 2021
    M0riTzx33 , Sep 28, 2021 :
    Yes I have 2.4 and 5ghz and both have the same name. Why should I change the name of one of them? With every other device its working just fine.
  14. Tokolozi
    Most Original Avatar Sep 28, 2021
    Tokolozi , Sep 28, 2021 :
    If it's possible just to rule out that that's the cause.
    My home network has the same setup, but can't replicate the issue here. That's why I suggested it as a troubleshooting step for now
    Caomhin likes this.
  15. M0riTzx33
    Donut Sep 28, 2021
    Changed the settings in the router so that 2,4 and 5 have different names. Added both to my phone and tried it again with instagram reels. It connected to the 5ghz one, was good at frist but started buffering again.
  16. Tokolozi
    So strange.... Really can't think of anything else from my side then.
  17. M0riTzx33
    Donut Sep 28, 2021
    I cant think of anything else either. My router is a good one (Fritzbox), other devices work like a charm. Software is up to date, connection is perfect. It happens with other WIFIs too, so my guess is that its either software or hardware related...
  18. Tokolozi
    Must be. There the feedback option is our only way to reach the devs that can look into it.
  19. M0riTzx33
    Donut Sep 28, 2021
    Where can I find the Feedback option? Was already looking for it, but couldnt find it. Is it in the settings?
  20. Caomhin
    OnePlus 9 Series Expert Community Expert Sep 28, 2021
    Caomhin , Sep 28, 2021 :
    Yes Fritzbox is one of the better if not best you can get.
    I had an issue onetime on my old 6T where I had to move the channels on 2.4Ghz to below 11 and 5 Ghz to between channels 40 and 100, not sure what caused the issue, but the 6T seemed to work after that, routers been on that ever since so my 9 Pro just works, haven't tried it on higher channels.
    Check if this might help.
