Wifi not working
  1. P1571757669765
    Cupcake Jan 22, 2021
    P1571757669765 , Jan 22, 2021 :
    I am using 7t pro and recently I am facing issues with my wifi, it gets connected to router but speed is almost like 0. where it work fine with my other device.
    Whether am I the only one facing the issue or anyone has the same issue.
  2. drl431
    Community Hero 2020 Jan 22, 2021
    drl431 , Jan 22, 2021 :
    Try resetting the networks:
    Settings > System > Reset options > Reset WiFi, mobile & Bluetooth.
    P1571757669765 likes this.
  3. P1571757669765
  4. J4t1np4r3kh
    OnePlus Accessory Tester Jan 22, 2021
    J4t1np4r3kh , Jan 22, 2021 :
    Can you try a speed test?
  5. J1611342747511
    J1611342747511 , Jan 22, 2021 :
    First of all turn-off and on your mobile again. Delete the saved network history from your mobile and try to set a new connection. Unplug your router and again plug it in and wait until it gets stable. Check if there are any other devices connected to your network
