wifi,playstore problem
  1. G_shams_al_mamun_aKmY Cupcake Jan 10, 2019
    G_shams_al_mamun_aKmY, Jan 10, 2019 :
    sorry for this post,I was searched before posting this, after updating 9.0 and 9.0.1 play store not working anymore,I mean I can't download anything and update anything from play store.i cleared the catch I did everything but still same.help me sort out this problem please, thanks in advance [e]1f64f[/e][e]1f60a[/e][e]1f60a[/e]
    rinku2bapi likes this.
  2. the_o2 Lollipop Jan 10, 2019
    the_o2, Jan 10, 2019 :
    Update to 9.0.2 :rolleyes:
  3. borft Jelly Bean Jan 10, 2019
  4. G_shams_al_mamun_aKmY Cupcake Jan 10, 2019
    bro I did few minutes ago.but still same no apps downloaded on play store ,I cleaned catch on play store even I wipe catch data.please take a look screenshot
  5. 严韬John Cupcake Jan 10, 2019
    严韬John, Jan 10, 2019 :
    I encountered the same problem as you, I'm OnePlus 5. the problem about play store.
  6. pablofg1978 Spanish POC Assistant Head Moderator Jan 10, 2019
    the_o2 likes this.
  7. G_shams_al_mamun_aKmY Cupcake Jan 10, 2019
    I have brother..I am in Germany now.whenever I try to download apps from play store or want to update apps mobile Internet speed or wifi speed just go down.
  8. G_shams_al_mamun_aKmY Cupcake Jan 10, 2019
    is there any solution for this?or I will be continue ?
  9. G_shams_al_mamun_aKmY Cupcake Jan 10, 2019
    I was try to find out solution,I was read every pin post brother,I just find only one thing that clear the cache,and I did but still facing same problem.
  10. 严韬John Cupcake Jan 10, 2019
    it seems like there's no solution about that. I will wait OTA.
    G_shams_al_mamun_aKmY likes this.
  11. the_o2 Lollipop Jan 11, 2019
    the_o2, Jan 11, 2019 :
    My play store version in 13.0.xx and your is 13.1.xx
    That's something related to play store too..
    Google do some random updates to random users.
    It's happens many times..
    My suggestion is to wait for 24 to 72hrs this problem will solve automatically...
    Few things I have noticed from your screenshot, first your Wi-Fi connection don't have stable connection or no internet see the ! Symbol on Wi-Fi icon...
    Second the VPN, don't use the VPN and then try normally, if it doesn't work just wait this issue will solved soon.
  12. Tarun.Khattar Donut Jan 11, 2019
  13. G_shams_al_mamun_aKmY Cupcake Jan 11, 2019
    G_shams_al_mamun_aKmY, Jan 11, 2019 :
    brother,it's my University Official VPN in Germany, before the update 9.0.0 it's ok but after the last 2update it's seems like play store not working,for the play store version I was downloaded latest Apk because of previous version not working and I thought maybe if I downloaded new version it will be ok but no it's same still now.i was waiting from the update 9.0 for fixing play store but still now same.
  14. G_shams_al_mamun_aKmY Cupcake Jan 11, 2019
  15. the_o2 Lollipop Jan 11, 2019
    Mate, first update the latest OS, version is 9.0.2 just released yesterday and then check whether problem is solved or not if not then uninstall the update of the Google Play store and then let it update to itself to 13.x.xx and then try.
  16. G_shams_al_mamun_aKmY Cupcake Jan 11, 2019
    I am using latest version 9.0.2 which was released yesterday.i uninstalled the update of play store last night.but nothing changes.ok let's wait for solving this issue automatically.thanks mate.
  17. rinku2bapi Gingerbread Jan 11, 2019
