Wifi problem via OnePlus 9R
  1. Sagor2020
    Cupcake Nov 27, 2021
  2. Aaron2017
    General Support Expert Award 2021 Nov 27, 2021
    Aaron2017 , Nov 27, 2021 :
    Do you have wifi scanning enabled? If so, try turning it off and see how it goes
    Sagor2020 and Caomhin like this.
  3. Sagor2020
  4. Aaron2017
  5. Caomhin
    9 Series Expert, Participator of the Year Community Expert Nov 28, 2021
    Caomhin , via OnePlus 9 Pro , Nov 28, 2021 :
    Further to @Aaron2017 suggestions.
    Reset your Network adapters, see if that helps.
    Settings, System, Reset Options, Reset WiFi Mobile Bluetooth.
    Also try the following. If the option is available to you.
    Disable "Sleep Standby Optimisation " in the
    Settings, Battery, Battery Optimisation, 3 dots menu top right, Sleep standby optimisation.
    Re-start your device.
    Also. Go to Settings, WiFi & Internet, WiFi, WiFi Preferences and disable Intelligently Select the best WiFi.
    Also check out additional possible solutions at the link below.
    How To Fix Common Wi-Fi Problems In Android
    https://www.techjunkie.com/fix-wi-fi-problem-android
    Aaron2017 likes this.
