2
Network/Connectivity Wifi range significantly dropped after 4.0.2 on Op 3.
  1. sshundal2006
    Gingerbread Jan 25, 2017
    sshundal2006 , Jan 25, 2017 :
    Wifi range significantly dropped after 4.0.2. Before I use to get full range in my bedroom while the wifi router is in my living room. Now it's on 1 Bar. Anybody else facing the same issue?
  2. Spidey_RP
    Donut Jan 25, 2017
    Spidey_RP , Jan 25, 2017 :
    nothing as such bro it's fine on mine. check ur wifi router. but you won't get internet continuously. am facing it
  3. sshundal2006
    Wifi router is fine I'm using it on Op 2 as well but facing issues on Op 3 only.
  4. ravi97
    Cupcake Jan 25, 2017
  5. vikeor
  6. BANCH3v
    BANCH3v , Jan 25, 2017 :
    Personally, I think the Wi-Fi is one of the few things that works fine after the update [e]1f601[/e]
