Wifi Saved But not Connecting !! Please HELP via OnePlus 8T
  1. E1607962971191
    Cupcake Oct 23, 2021
    E1607962971191 , via OnePlus 8T , Oct 23, 2021 :
    Hi,
    When I try to connect my company wifi, it's showing only SAVED but not connecting..
    Already Tried:
    1.Forgot Password
    2. Network Reset
    3. Factory Reset
    Is there any software bug? Please help
    Fed up with this...
    Planning to change my mobile If there is no solution..
  2. Cervantes
    Moderator Moderator Oct 23, 2021
    Cervantes , Oct 23, 2021 :
    Hello there
    You can connect to other wifi without problems ?
    You have asked your company's network administrator ?
    Caomhin likes this.
  3. E1607962971191
    Yes, I can connect other wifis
    Company WiFi has an encryption password, and once we try to connect with the password, it will usually redirect us to another web page.
    But something at that point prevents from going to the login page.
  4. Cervantes
    From what You say I think it is not a problem with the phone
    it may be problem of wifi permissions
    A router can be configured so that a phone enters or does not enter the Wi-Fi network
    OALEXANDER and Caomhin like this.
  5. E1607962971191
    Everyone else can connect to WiFi. Like something is blocking from going to the login page?
    Could this be a bug? Can this be fixed with software updates.
    i have already tried switching web browsers
  6. Cervantes
    You can check it with another wifi that has the same type of access
    puccellino and Caomhin like this.
  7. Cervantes
    You can give a bug report: Here
  8. Califormula
    Cupcake Oct 24, 2021
  9. puccellino
    Lollipop Oct 27, 2021
    puccellino , Oct 27, 2021 :
    Does your company have a dns server installed. Sometimes this causes problems. Best to talk to your IT guys.
  10. E1607962971191
    Cupcake Oct 27, 2021
    puccellino likes this.
  11. E1607962971191
  12. E1607962971191
    Cupcake Nov 3, 2021
    E1607962971191 , via OnePlus 8T , Nov 3, 2021 :
    Today I've got to know, one of colleague also have One plus phone and he also facing this difficulty. his phone is One plus 8 Pro. both of our phones running with Oxygen OS 11. thoughts please
  13. OALEXANDER
    Assistant Head Moderator Assistant Head Moderator Nov 18, 2021
    OALEXANDER , Nov 18, 2021 :
    Looks more specific to organisation infra.
    Have you reached out to your IT support ?
