WIFI SIGNAL GETTING UP & DOWN AUTOMATICALLY
  1. RIDER88
    Froyo Jun 24, 2018
    RIDER88 , Jun 24, 2018 :
    hi all,
    I haven't found any thread regarding this matter.
    one plus 3T, 5.0.3 stable build.
    my one plus 3t WiFi signals got automatically down and up even when I am in proper range of WiFi router. I have another Redmi note 5 phone and same is not facing with it. signals continuously fluctuating.
    please help to get it resolved.
    K1520421625645 likes this.
  2. 0slawek
    Jelly Bean Jun 24, 2018
    0slawek , Jun 24, 2018 :
    Oneplus 3/ 3t has 1x1 WiFi signal antenna so don't expect it to get good signal
  3. RIDER88
    Froyo Jun 24, 2018
    but same is working fine for me. I haven't face such issue but now it started.
  4. Sun90
    Starting Point Expert Community Expert Jun 24, 2018
    Sun90 , Jun 24, 2018 :
    Perform a cache wipe in recovery mode.
    And also restart your router once and see.
  5. RIDER88
    Froyo Jun 24, 2018
    done the same now em observing if problem still persist. thanks
    Sun90 likes this.
  6. RIDER88
    Froyo Jun 24, 2018
    still facing the same issues.. it's signal got completely disappeared and then return to full automatically.
    mean time note 5 still working fine.
  7. K1520421625645
    Cupcake Jun 24, 2018
    K1520421625645 , Jun 24, 2018 :
    Dear O+ Community,
    I had a wifi operation problem, same as 1stly mentioned. It is not stabile, I mean hardly find conncetion and always lost it. The speed very slow as well. I did not do any change on the phone. Local router tested, it works properly. Could you make a software update asap, please. It hardly effects my daily work. The hotspot works perfectly, so I guess it is not a hardware issue. Last Op on the device. Thank you.
    RIDER88 likes this.
  8. RIDER88
    Froyo Jun 27, 2018
    RIDER88 , Jun 27, 2018 :
    hello everyone... again I have another question...
    I have tested the WiFi speed through ookla internet speed test...
    em getting 8mbps + speed in my redmi note 5 but when I checked the same with one plus it's showing 3mbps speed.
    even it's network continuously fluctuate.
    any solution?? or I need to install naughat ROM??
    kindly suggest.
  9. 0slawek
    Jelly Bean Jun 27, 2018
    0slawek , Jun 27, 2018 :
    Oneplus has really bad antenna and combined with SISO module makes wifi on 3/3t really bad and it is well known since day1. 100/150$ phones can't beat op in terms of wifi speed but will have much better signal reception behing any obstacles.
    RIDER88 likes this.
  10. G_Imran_Sapiuddin_GFbe
    Cupcake Jun 29, 2018
  11. G_Neelmani_Jha_Yayt
    Gingerbread Jun 29, 2018
  12. RIDER88
    Froyo Jul 1, 2018
  13. H1528103213622
    Cupcake Jul 1, 2018
    H1528103213622 , Jul 1, 2018 :
    iam also facing the same issue since the update. even check for hotspot, same issue is there. hotspot is set at hidden I can't make it visible to my devices.
    oneplus please give a solution to this.....
  14. H1528103213622
    Cupcake Jul 1, 2018
