wifi speed slower than nexus 6p
  1. arabinow Cupcake Dec 7, 2017
    arabinow, Dec 7, 2017 :
    Has anyone noticed slower wifi speeds on the OnePlus 5t. I have gigabit internet at home with Google wifi routers. my Nexus 6p will get download speeds of 100+ and uploads of 100 easy but when I do a speed test on the one plus 5t using the same servers it's always slower in the 50-60 range.
    anyone have a clue ?
  2. kevinkrg6 Honeycomb Dec 7, 2017
    kevinkrg6, Dec 7, 2017 :
    it seems slower perhaps yes.
    idk, it's not a Google phone
    those are more expensive.
    this is a cheaper phone.
  3. G_Udgeet_Koul_PzIT Cupcake Dec 7, 2017
  4. V1511447954247 Eclair Dec 7, 2017
  5. N1512621685913 Cupcake Dec 7, 2017
    N1512621685913, Dec 7, 2017 :
    No, it can't be.Wifi speed in OnePlus 5 and OnePlus 5t supports Mimo 2*2 , regarding the speed of wifi it will give competition to iPhone x for sure. I tested it and my wifi speed is too fast
  6. kevinkrg6 Honeycomb Dec 7, 2017
    Too fast!
    Uh oh, you better slow
    down or you're gonna crash!
  7. L1512669608386 Donut Dec 7, 2017
    L1512669608386, Dec 7, 2017 :
    I've found the option to display network speed can't be right as I get 200 mbs and the phone says I'm getting like 0,5 k/s or like 2 m/s keeps changing all over the place , but ive downloaded the speed test app and that says I'm getting what I should be
  8. Joeynbgky Froyo Dec 7, 2017
    Joeynbgky, Dec 7, 2017 :
    is it set to 5ghz? in settings? if not switch to auto or choose 5ghz over 2.4
  9. RobertOH Donut Dec 7, 2017
    RobertOH, Dec 7, 2017 :
    Mine has reached over 250Mb/s according to Ookla.
    It's a pity that Ookla is only 1 of 3 Apps that will work won't with WIFI though! The rest of the phone won't load anything. 250Mb would be great for streaming.
  10. arabinow Cupcake Dec 7, 2017
    I have used both auto and set to 5 GHz and stood right next to router. oh well fast enough.
  11. MarcioReis87 Ice Cream Sandwich Dec 8, 2017
    MarcioReis87, Dec 8, 2017 :
    my router is downstairs separated by 4 thick walls. estimated distance 50m and I'm getting Max speed that my ISP permits which is 100/100
    I'm on 5Ghz all the time btw
