Wifi speed
  1. AH Jihad
    Donut Aug 1, 2019
  2. Horsault
    Marshmallow Moderator Aug 1, 2019
    Horsault , Aug 1, 2019 :
    5G isn't a speed.
    It's either a data norm evolution to go beyond 4G, or a Wifi frequency (5GHz) that has nothing to do with network speed.
    Kytharsis and drl431 like this.
  3. AH Jihad
    Donut Aug 1, 2019
    AH Jihad , Aug 1, 2019 :
    actually i mean it [e]1f60a[/e]
  4. Horsault
    What is your question exactly?
    To use 5GHz band, you need to connect to a Wifi hotspot set to 5GHz.
    Starcommander and Kytharsis like this.
  5. AH Jihad
    Donut Aug 1, 2019
    yeah..
    I want to set 5GHZ on my mobile.
  6. Horsault
    From OP5 at least, all OnePlus devices can access 5GHz wifi hotspots. What is your real point?
  7. AH Jihad
    Donut Aug 1, 2019
    you mean hotspot but i don't need hotspot speed 5GHz, i need mobile wifi speed 5GHz.
  8. Horsault
    I think I wasn't clear enough.
    Wifi maximum speed will be 10 530 Mbps for Wifi 6 (code name ax) in the future.
    According to norm, Wifi hotspot can transmit on 2.4, 5 or 60 GHz frequency band.
    As you see, transmission frequency band is different from data speed.
    Your device can work with 2.4 and 5GHz hotspots and is compatible with Wi-Fi 802.11 a/b/g/n/ac.
    Actual transfer speed will depend on your hotspot norm, its strength, how far you're from it, and how many people are sharing it.
    ironass, drl431 and Kytharsis like this.
  9. AH Jihad
    Donut Aug 1, 2019
    you are correct.
    but how to change this speed? (follow picture)
  10. Horsault
    FOR THE LAST TIME: THIS IS NOT SPEED!!!
    THIS IS TRANSMISSION FREQUENCY BAND.
    ironass, sagarshenoy and Kytharsis like this.
  11. Kytharsis
    Marshmallow Aug 1, 2019
    Kytharsis , Aug 1, 2019 :
    He's hopeless. Also, since when is 60 GHz a thing and what has that much throughput to be useful?
    Nabodit, drl431 and Matt 80 like this.
  12. Matt 80
    Lollipop Aug 1, 2019
    Matt 80 , Aug 1, 2019 :
    The phrase "banging your head against a wall" comes to mind here.
  13. AH Jihad
    Donut Aug 2, 2019
    AH Jihad , Aug 2, 2019 :
    ok.
    how to change translation frequency band 2.4 GHz to 5 GHz?
  14. LorenStuck
    Honeycomb Aug 2, 2019
    LorenStuck , Aug 2, 2019 :
    Connect it to a wifi router that uses the 5Ghz frequency.
  15. RyanMixed
    Froyo Aug 2, 2019
    RyanMixed , Aug 2, 2019 :
    Usually 5 GHz does have a faster speed when transferring your internet but it lacks accuracy why would you want to switch to 5 GHz it already does it automatically if you're near 5ghz if you're far 2.4 thats how it usually works you cant change it.
  16. Priyanshu Sharma
    Jelly Bean Aug 3, 2019
    Priyanshu Sharma , Aug 3, 2019 :
    That is *TRANSMISSION FREQUENCY* not Translation Frequency!! Why the hell I'm on earth!![e]1f60c[/e]
    You have to change your band to 5Ghz from your Router Setting (NOT PHONE*)... Go to your router settings and find option to change band frequency from there and make sure your router supports 5Ghz band!!
  17. Starcommander
    KitKat Aug 3, 2019
    Starcommander , Aug 3, 2019 :
    Speed will be the same, the wifi strength will be more with 5ghz and latency will be less. However the speed will depend on the internet provider.
    Kytharsis and Matt 80 like this.
  18. Anandu p
    Gingerbread Aug 3, 2019
  19. Bilalazeem54
    Gingerbread Aug 11, 2019
    Wirelessss likes this.
