WIFI stability issue with one plus 6
  1. bhargavgondi
    Cupcake Dec 31, 2018
    bhargavgondi , Dec 31, 2018 :
    Hi I have upgraded my one plus 6 to oxygen os 9.0.3 but still see some issue with WiFi stability. is any one else facing this issue.
  2. fastbyte
  3. bhargavgondi
    its not having WiFi issue. WiFi is getting connected even though it is off. before it only was only getting automatically connected to WiFi I use at my home. now any WiFi it detects it's getting connected.
  4. fastbyte
    fastbyte , Dec 31, 2018 :
    the phone connects to the wifi it know, WiFi that you have been connected at least one time . Are you seeing the notification that say that a wifi network is available? Have you tried to change the options on wifi settings?
  5. bhargavgondi
    yes any WiFi network available it shows. and my home WiFi it connects automatically
  6. fastbyte
    If your problem is the notification go to the WiFi settings and change to option that notify you when there is an open WiFi network.
  7. bhargavgondi
    fastbyte
    If your problem is the notification go to the WiFi settings and change to option that notify you when there is an open WiFi network.​
    sure will try and let u know. thanks
  8. fastbyte
    have you solved your problem?
  9. bhargavgondi
