3
WIFI won't work fine at Android 10 via OnePlus 6T
  1. Installazion
    Donut Oct 27, 2019
    Installazion , via OnePlus 6T , Oct 27, 2019 :
    I've updated my phone to android 10 today but I can't connect to my WiFi, the Telekom Hotspot ist working just fine. what's happening?
    that error is there since the first android 10 beta
  2. AaSchmi
    Cupcake Oct 27, 2019
    AaSchmi , Oct 27, 2019 :
    I got the same issue but didn't find a solution yet.
    Strangely enough, some networks work (like a mobile hotspot from the PC or other wifis) and others do not work at all.
    ms14 likes this.
  3. CindyYor
    Cupcake Nov 5, 2019
    CindyYor , Nov 5, 2019 :
    Just updated to 10 as well on a OP6 and noticing the same issue. I can connect to 2.4 Ghz networks but not 5GHZ.
    Many home network (around me, at least) have dual band frequencies. One is 2.4 and another is 5. by default, the networks will be called "NETWORK" for 2.4 and "NETWORK-5G" for 5
    Check and see if you are able to connect to 2.4 and/or 5. Maybe that is the issue we are having?
    ms14 and Francesco Meo like this.
  4. Ashiqur Rahaman
    Cupcake Nov 6, 2019
    Ashiqur Rahaman , Nov 6, 2019 :
    I can't see my 5ghz band though my dual band is on. So i can't connect to 5G. Do you have any solution for this?
    raxuz likes this.
  5. raxuz
    Donut Nov 8, 2019
    raxuz , Nov 8, 2019 :
    I have issues with WiFi too. I can't connect to either 5G or 2.4G wifi Network restarted, phone settings reset. Test with different encryptions wpa, wpa2, router restart. Nothing works. How is it possible that oneplus missed this issue?
    All other nodes on my network runs fine. Only my oneplus 6 that has issues and they came with android 10.
    Running a asus rt-ac88u router
    ms14 likes this.
  6. Francesco Meo
    Eclair Nov 8, 2019
    Francesco Meo , via OnePlus 6T , Nov 8, 2019 :
    Same thing for me too. It connects to 2.4 but not to 5ghz ... Bho
  7. raxuz
    Donut Nov 9, 2019
    raxuz , Nov 9, 2019 :
    Bug found that breaks WiFi, if network uses mac filter the one plus won't connect. Oneplus has broken the possibility to uses mac filter on network.
    Let's hope a bug fix comes soon
  8. JMO19DELTA
    Cupcake Nov 10, 2019
    JMO19DELTA , Nov 10, 2019 :
    Same problem here. Also, have issues with Bluetooth not connecting to car audio as well.
