Wifi via OnePlus Nord CE
  1. sasipreetham25
    Cupcake Oct 16, 2021
  2. Caomhin
    OnePlus 9 Series Expert Community Expert Oct 18, 2021
    Caomhin , via OnePlus 9 Pro , Oct 18, 2021 :
    You must have a network provider who provides the VoLTE/VoWifi service on your mobile plan.
    The VoLTE/VoWifi settings will be in your Sim & Network settings, if its not showing and you have a Network provider that supports it as well as a good 4G LTE signal then try the following to see if this will enable it.
    This is for all OP phones, however it discuses the 8 Series, but it should apply to any series as the protocols are the same.
    [GUIDE] Enable VoLTE & VoWiFi on all devices NO ROOT.
    https://forum.xda-developers.com/on...nable-volte-vowifi-devices-root-t4105817/amp/
    Log Kit 1.0
    https://www.apkmirror.com/apk/onepl...ase/onepluslogkit-1-0-2-android-apk-download/
    There are newer versions but I would suggest trying this with the details provided on XDA.
