9
WIFI
  1. needyleopard
    Cupcake Nov 24, 2018
    needyleopard , Nov 24, 2018 :
    Is anyone's WiFi is not working properly after getting the oxygen os update because mine is not working properly. It get disconnected after some time automatically. It's a serious problem.
  2. G_Rahul_Lunavath_PyMA
  3. manuplus22
    Gingerbread Nov 24, 2018
  4. Waveform Modifier
    Marshmallow Nov 24, 2018
    Waveform Modifier , Nov 24, 2018 :
    Nope. Works fine here.
    G_David_Sidrak_rYck likes this.
  5. G_Rahul_Lunavath_PyMA
  6. Ithrial
    Cupcake Nov 25, 2018
    Ithrial , Nov 25, 2018 :
    I've been having all sorts of issues where wifi will drop in and out. I'll have full strength on 5GHz and then about a minute later it'll reset. Reboots, Bluetooth off and reset of network is no help.
    Running Unifi AC APs
    Rohan313 and G_Shivam_Kohli_RbwP like this.
  7. vikassaikapian
    Froyo Nov 25, 2018
    vikassaikapian , Nov 25, 2018 :
    Than what.. Are you the representative of one plus.. May be working for u perfectly but not for that user...
  8. borft
    Jelly Bean Nov 25, 2018
    borft , Nov 25, 2018 :
    but that is what he asked. it's working fine for me as well
    Waveform Modifier likes this.
  9. G_Shivam_Kohli_RbwP
    Cupcake Nov 26, 2018
  10. Chiliry
    Eclair Nov 27, 2018
    Chiliry , Nov 27, 2018 :
    same here, I'm having inconsistent wifi connection when all my other devices are completely fine.
  11. needyleopard
    Cupcake Nov 28, 2018
    needyleopard , Nov 28, 2018 :
    the big problem arises when you are transferring something through shareit app I hope they fix it soon.
  12. J_Parth_Patel_120595
    Gingerbread Nov 28, 2018
    J_Parth_Patel_120595 , Nov 28, 2018 :
    I am experiencing the same issue, started after 9.0.6 update... WiFi randomly disconnects and reconnects... no problem on my other devices.
    A1582312778408 likes this.
  13. NishanthNanu
    Donut Dec 4, 2018
    NishanthNanu , Dec 4, 2018 :
    Same problem here. Full strength 5ghz WiFi connection. but it automatically disconnects and reboot then connect. It is a serious problem while playing PUBG and unable to share anything through share it app.
    G_Shivam_Kohli_RbwP likes this.
  14. ruijmeira
    Gingerbread Dec 4, 2018
  15. G_JohanTv1_OuHu
    Cupcake Dec 6, 2018
    U1527917758122 and Rohan313 like this.
  16. Chiliry
    Eclair Dec 6, 2018
    Chiliry , Dec 6, 2018 :
    it's still happening and it's making me go insane because I want to use 5ghz wifi so bad [e]1f62d[/e] I recorded my issue and I hope this demonstrates the issue that everyone else here is having
  17. G_Shivam_Kohli_RbwP
    Cupcake Dec 6, 2018
    G_Shivam_Kohli_RbwP , Dec 6, 2018 :
    mine is not even connecting lol wifi isnt even starting nor bluetooth is working. poor oneplus
    Rohan313 likes this.
  18. NishanthNanu
    Donut Dec 6, 2018
    NishanthNanu , Dec 6, 2018 :
    superb this is what one plus needed as proof. same problem facing here. Good video. Kindly Oneplus should check and solve this.
  19. PokiX
    Jelly Bean Dec 6, 2018
    PokiX , Dec 6, 2018 :
    No
    It's actually very stable. I run ssh to connect to servers and it keeps hours connected with screen off.
    I didn't touch anything, it works out of the box.
    Provide a detailed way to reproduce the problem and you might get help.
  20. NishanthNanu
    Donut Dec 6, 2018
