WiFy speed is severely reduced during phone call via OnePlus 8T
  1. kkdigi
    Eclair Apr 18, 2021
    kkdigi , via OnePlus 8T , Apr 18, 2021 :
    I am using a 70Mbps 2.4GHz wify. But during a phone call I am getting less than 10 Mbps, even less than 1 Mbps sometimes. I checked multiple times . I am on 8T, latest update 11.0.8.12, indian variant.
  2. NaXal
    Gingerbread Apr 18, 2021
    Best Answer
    NaXal , via OnePlus 8T , Apr 18, 2021 :
    Are you using Bluetooth? They both work with 2.4GHz network.
    Try using different WiFi channel viewing apps to see if you are in a too much crowded air wave location.
    Try to change the WiFi channel to a different one and then test.
    Thanks.
  3. Tokolozi
    Most Original Avatar Apr 18, 2021
  4. kkdigi
    Eclair Apr 18, 2021
    No, I was using Vowify....but because of this problem, call quality was extremely worse, so I had to turn off the Vowify..now I am only using Volte...even wile connected to wify....on a side note, mobile data speed is not impacted during call.
  5. Tokolozi
    Tokolozi , Apr 18, 2021 :
    Then it would be best to report it via the feedback tool in the community app.
  6. kkdigi
    Eclair Apr 22, 2021
    kkdigi , via OnePlus 8T , Apr 22, 2021 :
    Yes I was using bluetooth neckband during call. I'll check without bluetooth, then update.
  7. kkdigi
    Eclair Apr 22, 2021
    You are right, bluetooth was the problem...guess I have to use a 5 GHz router to avoid this problem. And thanks for the wify channel tip, it was of great help. I changed my wify channel and the speed is significantly increased.
  8. .Deleted_Member.
    Nougat Apr 22, 2021
    .Deleted_Member. , Apr 22, 2021 :
    yaaaaaaaayyyy!!!
