Will I get Warp Charging if I use third party cable? via OnePlus 7 Pro
  1. #1
  2. drl431
    Junior Moderator, Community Hero 2020 Junior Moderator Dec 26, 2020
    drl431 , Dec 26, 2020 :
    Its possible, but you might have to try several 3rd party cables to find one that supports warp charging. I believe a VOOC compatible cable could work.
    Aditya Javadekar and Artemus like this.
  3. _Bharat_
    Gingerbread Dec 26, 2020
  4. McJader
    Marshmallow Dec 26, 2020
  5. LokGubhaju
    Froyo Dec 26, 2020
  6. Horsault
    Moderator Moderator Dec 26, 2020
    Horsault , Dec 26, 2020 :
    OnePlus fast charge technology uses high current rather than high voltage like many other solutions.
    It designed to work with original power brick + cable + OnePlus device (obviously).
    When choosing a 3rd-party cable, be sure it can handle high current.
    In any case, you'll get maximum speed the weakest part can handle. Using a normal cable, you'll get normal charge. Using a 2A rated cable, you'll have chance to get 10W charge. Etc.
    Tokolozi likes this.
  7. Tokolozi
    Most Original Avatar Dec 26, 2020
    Tokolozi , Dec 26, 2020 :
    For oneplus 8 pro and lower... No
    For the 8T, any cable that uses the usb PD protocol and has 65W capability, it will work.
  8. Larskon
    Honeycomb Dec 28, 2020
  9. E1598532882379
    Cupcake Oct 15, 2021
    E1598532882379 , Oct 15, 2021 :
    Are you sure, because I've been looking for this info for days.
    OnePlus 8T + OnePlus 65 WarpCharge Charger + any USB C cable with PD and 65 watts or more like Anker Powerline III 100 watt = 65 watts charge.
    What about the following combination.
    OnePlus 8T + any 65 watt or more charger like Anker Nano II 65 watt + any USB C cable with PD and 65 watt or more like Anker Powerline III 100 watt = 65 watt charging?
    If you can answer that, I would really appreciate it. I'm looking for smaller cable and charger for travel and if I know that then possibly only 27 watts are supported, I do not need to get me a 65 watt charger.
  10. Tokolozi
    Most Original Avatar Oct 15, 2021
    Tokolozi , Oct 15, 2021 :
    Hey, it should work, however IIRC the 8T actually only charges at 45W, but comes with a 65W charger. For a travel charger a 45W might be easier to find then :)
    E1598532882379 likes this.
  11. E1598532882379
    Not sure if I'm understanding you correctly. With the original 65 watt charger, the 8t already charges with 65 watts - at least that's how it's described on the OnePlus website. It is only missing the info with how much it charges with third party charger and cable. Also, the technical support gives no information and says only "we recommend only original charger and cable to use".
  12. Tokolozi
    I use a normal Anker USB PD bank for my daily charging (multi port charger) it works at what I would consider the normal warp speed on the 8t of my girlfriend. At most maybe a few minutes difference, never really timed it.
  13. E1598532882379
    E1598532882379 , via OnePlus 8T , Oct 15, 2021 :
    Ok thanks for you answer, that helps me,
