Other Will it erase all internal storage if I "Install from internal storage"
  1. L1523741956027
    Cupcake Jan 19, 2019
    L1523741956027 , Jan 19, 2019 :
    Hi all oneplus users,
    I wanna flash stock rom from offical site so I flashed stock recovery. But I wondered that if I flash stock rom from stock recovery, it will erase my internal storage like photos, songs, documents etc. or only app data?
    Thanks
  2. the_o2
    User of the Year 2018, OnePlus 9 Series Expert Community Expert Jan 19, 2019
    the_o2 , Jan 19, 2019 :
    Nothing personal data will deleted (if you are on stable version,
    if you are moving from beta to stable than yes you have to do so ),
    But it's always good to have backup of important data, in case anything wrong happened :)
    Praty_28 and L1523741956027 like this.
  3. L1523741956027
    Thanks your quick reply. I was erased all system and other partition like boot, efs etc. from twrp and then flashed stock rom but it gives errors so that i flashed stock recovery. But I need to reinstall twrp and then backup my data in case of something goes wrong and it will be bad.
  4. the_o2
    Well I'm not that good in this these days so going to tag some person hope they help you.
    @B_Wrath @BeingIncog @xnutzii
    xnutzii likes this.
  5. xnutzii
    Lollipop Jan 19, 2019
    xnutzii , Jan 19, 2019 :
    Which twrp have you tried to install? Have you tried the blu_spark?
  6. L1523741956027
    yes bluespark but latest version for pie wont boot so that twrp 3.2.2 bluespark installed and then mtp now is available
  7. xnutzii
    hmm alright, you mind to elaborate your current state again? Maybe I can help out here, if not, @B_Wrath is the king in literally anything.
  8. L1523741956027
    Thanks Now I'm waiting to copy backup to pc and then I'll try it and I'll write that if wipe or not. I dont want take risk because the data important.
  9. xnutzii
    alright, i understand.
  10. L1523741956027
    Even if I try to flash stock recovery it fails because of /vendor partition (I think something related to Project Treble) so I restored my backup for now because I think it requires using a tool (something like this tool (axon-7 devices but not sure it works on this phone) ) to repartition of internal memory to get /vendor partiton. I also updated the updater-script from the zip to bypass security check like comment out first three lines and abort statement but it stuck on Logo.
    So now if you have a solution without this I wanna try it out.
    Thanks for your help.
  11. B_Wrath
    Moderator Moderator Jan 20, 2019
    B_Wrath , Jan 20, 2019 :
    What rom are you currently on?
  12. L1523741956027
    Cupcake Jan 20, 2019
    L1523741956027 , Jan 20, 2019 :
    "xXx_NoLimits_10.5_OP5_Oxygen_5.1.1" Oreo , OOS 5.1.1
  13. B_Wrath
    Thanks for the tag guys.
    @xnutzii I won't agree with the king part though:p
    xnutzii and the_o2 like this.
  14. B_Wrath
    Try this stock recovery
  15. L1523741956027
  16. xnutzii
    Lollipop Jan 20, 2019
    B_Wrath likes this.
  17. L1523741956027
    Cupcake Jan 22, 2019
    L1523741956027 , Jan 22, 2019 :
    I tried this but it doesn't read internal storage so that I flashed older version of stock rom and finally nougat version has been boot but it says your phone is decrypted and it forces to use encrypted userdata partiton to use stock rom. After that I format the userdata partition and then i flashed all ota from phone via system updates. Finally I boot twrp one time from "fastboot boot method" to install Magisk and now everything is OK. Stock recovery, OTA is available and root access granted.
    Thanks for your helps.
