Will oneplus 9 pro bought from USA works flawlessly in india? via OnePlus 6T
  1. Aaqilfas
    Gingerbread Sep 17, 2021
    Aaqilfas , via OnePlus 6T , Sep 17, 2021 :
    Specially will I get red cable club etc?
    Can i flash indian ROM?
    Any other things to check while purchasing?
  2. Tobikage
    Nougat Sep 17, 2021
    the_o2, Aaqilfas and Tokolozi like this.
  3. Aaqilfas
  4. Tobikage
    Nougat Sep 17, 2021
    Tobikage , Sep 17, 2021 :
    You can flash the Indian ROM sure....but
    there is a reason regional variants exist.
    Enjoy your warranty-less and unsupported gift !
    the_o2 and Aaqilfas like this.
  5. Xcommunicad0
    Lollipop Sep 17, 2021
    Xcommunicad0 , via OnePlus 8T , Sep 17, 2021 :
    I think it won't have any Warranty anyway once it's outside USA.... Flash or not.
    Aaqilfas likes this.
  6. Xcommunicad0
    Hi, would suggest to check with the support team for RCC options but if you don't plan to use it again in USA then flashing to IN version will get you OTA updates and better compatibility with local Carrier network as well.
    Please do note that some features are region specific and may not be available or support.
  7. harshit.b.
    Ice Cream Sandwich Sep 17, 2021
    harshit.b. , via OnePlus 6 , Sep 17, 2021 :
    You might also want to check if the network bands are compatible. Different variants might only have network bands specific to their region.
  8. Akshat Sehgal
    Akshat Sehgal , via OnePlus 9R , Sep 17, 2021 :
    The one thing to note is that the US variant doesn't have support for dual sims. Theoretically, you can flash the Indian rom and get a dual sim tray and it should work but it's too much work. Plus the US variant would cost you more ($1069= ₹79,106). The Indian variant costs ₹69,000. Save the 10k and buy the OnePlus buds Pro 😉
  9. Aaqilfas
    Gingerbread Sep 18, 2021
    Aaqilfas , via OnePlus 6T , Sep 18, 2021 :
    They dont have dual sim😬?? , I didnt check that part
    Thanks👍🏻
  10. the_o2
    OnePlus 9 Series Expert Community Expert Sep 18, 2021
