Wireless bluetooth earphone connectivity issue - reg via OnePlus 6
  1. R.Nagarajan
    Cupcake Oct 20, 2021
    R.Nagarajan , via OnePlus 6 , Oct 20, 2021 :
    After few security and android 11updates wireless Bluetooth earphone connect and disconnect automatically while using, I had replaced wireless bluetooth earphone also afterthat same problem continues. So kindly fix the Bug
  2. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Oct 20, 2021
    Artemus , Oct 20, 2021 :
    Do you have Alibaba installed on your phone?
  3. R.Nagarajan
  4. Artemus
    Okay, so it's not that issue then. Hm.
    Have you tried factory resetting your phone?
  5. R.Nagarajan
  6. Azifcp
    Froyo Oct 23, 2021
  7. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Oct 23, 2021
    Artemus , Oct 23, 2021 :
    For some odd reason the Alibaba app is affecting Bluetooth audio from playing on the device and reroutes it to the phone's speaker. Uninstalling it seems to be the solution to it, it seems.
    Azifcp likes this.
