Wireless display on Oneplus TV via OnePlus 6
  1. Siddhardha Seetala
    Cupcake Oct 23, 2019
    Siddhardha Seetala , via OnePlus 6 , Oct 23, 2019 :
    How to connect Windows 10 wireless display on Oneplus TV?
    Can anyone please guide on this?
    It doesn't show up on my wireless display devices list on windows 10. Both are connected to same wifi.
  2. Venky61
    Jelly Bean Oct 24, 2019
    Venky61 , Oct 24, 2019 :
    Hey... The wireless display on Windows PC is based on Miracast and the one on Android TV is Chromecast. You can cast your screen by using cast option on chrome browser. Hope this helps.
  3. Siddhardha Seetala
    Cupcake Oct 25, 2019
    Siddhardha Seetala , via OnePlus 6 , Oct 25, 2019 :
    Hi.. Thank you.
    I was wondering if there is a way around to get the Miracast support. I'm not aware of the hardware requirements for the same.
  4. Venky61
    Jelly Bean Oct 25, 2019
    Venky61 , Oct 25, 2019 :
    Google has stopped the support for Miracast... So the only way is by using Chromecast browser.
  5. #5
    Venky61 likes this.
  6. shubham54000
    Cupcake Oct 26, 2019
    shubham54000 , Oct 26, 2019 :
    I recently purchased OnePlus TV Q1 (55"), using Samsung Galaxy Note 9, everytime I try to mirror my mobile screen, TV shows in "Smart View" but does'nt connect. Tried Several Times, even Reset OnePlus TV, but still not working, downloaded OnePlus TV "Connect" App and tried through it but no luck, Both Mobile and TV are connected with same Wifi Router, Any help and suggestions please?
  7. Venky61
    Jelly Bean Oct 27, 2019
    Venky61 , Oct 27, 2019 :
    Try this.
    Install Google Home App and add OnePlus TV in devices. After that go to profile and select mirror device. This should work.
  8. shubham54000
    Cupcake Oct 28, 2019
    shubham54000 , Oct 28, 2019 :
    Google Home not detecting OnePlus TV, its only showing in Samsung Smart View Menu for Mirroring/Casting the screen to TV, but its not connecting.
  9. Venky61
    Jelly Bean Oct 28, 2019
    Venky61 , Oct 28, 2019 :
    Can you try with 3rd party apps like Air Screen or All cast and check once.
  10. shubham54000
    Tried but not working
  11. Eddy W.
    OnePlus TV Software Engineer Staff Member Nov 1, 2019
    Eddy W. , Nov 1, 2019 :
    It looks like the wifi router has turned off multicast or broadcast services by default.
    Have you tried other brands of phones?
  12. shubham54000
    Cupcake Nov 1, 2019
    shubham54000 , Nov 1, 2019 :
    Eddy W.
    Have you tried other brands of phones?​
    Ya, tried OnePlus 6T Mclaren Edition of my father, does not work with it either.
    Router- D Link DIR 816
  13. shubham54000
    Cupcake Nov 1, 2019
  14. Eddy W.
    Ok, maybe we can do a test to determine the cause.
    step 1: use Oneplus 6T to create hotspots
    step 2: TV & Samsung Galaxy Note 9 join the hotspots
    step 3: check if the Note 9 can detect tv, via Connect/AllCast
    Looking forward to hearing from you ^ ^
    shubham54000 and Venky61 like this.
  15. shubham54000
    Cupcake Nov 1, 2019
    You are an absolute charm! this time, screen mirroring works!
    Procedure I follow-
    Step 1: Create a Hotspot on my Mom's OnePlus 5T (6T is not available for now)
    Step 2: Connected my OnePlus TV & Samsung Galaxy Note9 on that Hotspot.
    Step 3: Launched AllCast App and this time, my Galaxy Note 9 successfully detected OnePlus TV and screen mirroring works like a charm. As my AllCast app is free version, trial preview is short.
    I guess my Modem has some issues, or maybe a setting in modem is disabled which can't able to cast any screen to TV.
  16. Eddy W.
    Wow ~ this is a good news, I am really happy to help you.
    Maybe you can check the MDNS service of the router, it must be enable to support Cast.
    Venky61 and shubham54000 like this.
