Network/Connectivity Wireless transfer of PC files - OnePlus 9 Pro.
  1. Kenas96
    Froyo Oct 19, 2021
    Kenas96 , Oct 19, 2021 :
    Hi!
    Do you know how to transfer files wirelessly between PC and oneplus 9 pro? Need an app from the play store?
  2. J4t1np4r3kh
    OnePlus Accessory Tester Oct 19, 2021
    J4t1np4r3kh , Oct 19, 2021 :
    There are many apps that can do this.
    You could also do it over Bluetooth if your PC had the capabilities.
    Or, what I personally do, is use Google Drive. Upload your files there, and then download them from your online account
  3. Kenas96
    Froyo Oct 19, 2021
    I mean more about something that I have a wireless view to the phone what files are and the ability to copy them, etc.
  4. J4t1np4r3kh
    Ahh I see.
    I know the file commander app can do this. There are probably loads more apps similar to this
  5. Chris1223
    Honeycomb Oct 19, 2021
  6. RazvanScutea
    Gingerbread Oct 19, 2021
    RazvanScutea , via OnePlus 9 Pro , Oct 19, 2021 :
    That application is strictly for clipboard. Text coping. He wants to transfer files from phone to PC ( multimedia files like images, ringtones, music , documents etc ). Something like air drop on iphone
  7. Chris1223
    Chris1223 , via OnePlus 9 Pro , Oct 19, 2021 :
    That's not true. I personally have sent multiple images using this method. According to the Play store description you can transfer files this way too. It's more than just the clipboard you can share directly to the app which will then put it up there for it to be accessed from other devices. To test this I just sent an Excel document from my cell phone to my computer without a problem. the cell phone was using cell service and the laptop was using Wi-Fi (using completely different networks or the same network it still works).
  8. Chris1223
    Honeycomb Oct 20, 2021
    Chris1223 , via OnePlus 9 Pro , Oct 20, 2021 :
    This description even goes on to say that you can move video from a phone to other devices. I have included a screenshot of the description for clipt..
  9. FirefoxSys
    Cupcake Oct 21, 2021
    FirefoxSys , Oct 21, 2021 :
    I have been using File Manager Pro for some years that allows you to access the phone folders via WiFi from your PC. Just activate sharing from your phone and then type the indicated address into the browser.
    I find it useful when you need to transfer files but don't want to recharge your smartphone by connecting it via USB cable. I think it costs some money (having bought it now in the PlayStore I don't see the price) but it is functional and has good graphics. If I remember correctly there is also a free version to try it out before buying the paid one.
  10. Xcommunicad0
    Lollipop Oct 21, 2021
    Xcommunicad0 , via OnePlus 8T , Oct 21, 2021 :
    Have you tried "FileDash" option of OnePlus File Manager?
    It's inbuilt functionality of OnePlus File Manager; you may not require any third party apps for this..
  11. Chris1223
    Honeycomb Oct 21, 2021
    Chris1223 , via OnePlus 9 Pro , Oct 21, 2021 :
    "FileDash" is gone from OnePlus 9 series and replaced with Androids nearby share (built directly into the operating system). From a quick internet search nearby share only works with chrome after enabling a flag.
  12. Xcommunicad0
    It keeps coming back, just check if you have the latest version or wait for the next updates.
    If still not then high probability will come back with some other updates.
