Without any physical damage my nord's wrap cable is not supporting wrap charge bought 8 months ago. via OnePlus Nord
  1. H1603326036578
    Cupcake Jun 20, 2021
  2. Shailender Sharma
    Nougat Jun 20, 2021
    Shailender Sharma , Jun 20, 2021 :
    Try to disable Optimised Charging in the Battery Settings. Use any other power socket to check and verify the warp charging.
    Also Clean the USB Port -
    Charging problems may be caused by debris blocking the physical connections in the charging port. Dirt, dust and lint can get between the metal pins of the charging cable and charging port, preventing electricity from flowing. If this is the case, gently swab the connection port with a toothpick to remove any debris. Be careful not to damage the connector pins.
  3. H1603326036578
    H1603326036578 , via OnePlus Nord , Jun 20, 2021 :
    Thanks for your response,
    But I tried still not supporting wrap charge.
    Also tried with another realme cable then showing wrap charge, but not with OnePlus cable.
    With OnePlus cable charging shuffling wrap and normal slow charging continuously
  4. psygarden , via OnePlus 8T Aquamarine Green , Jun 20, 2021 :
    Seems like Cable has been damaged. You'll need to replace it with a new one.
  5. #5
  6. #6
  7. HYPERHARSHAD27
    Cupcake Jun 21, 2021
    HYPERHARSHAD27 , Jun 21, 2021 :
    Yes dude Correct, My mistake so ... I think you have to buy new one.
  8. H1603326036578
