2
Workaround for Blank Screen Cast Issues
  1. PrabhatNagpal
    Eclair May 19, 2019
    PrabhatNagpal , May 19, 2019 :
    Hi Guys,
    I am writing this post to help people who are experiencing issues in screen casting apps like Hotstar, Netflix, JioTV etc., mostly getting a blank screen on their Smart TVs. When they try to screen cast the apps while playing any video content on the apps, they are able to get the audio feedback from TV but no video feedback, just a blank screen.
    NO ROOT REQUIRED!
    Please follow the below steps to get expected screen cast from their Smart TVs:-
    Step 1: Download and install VirtualXposed application from this link.
    Step 2: Open the application and click on the launcher menu button
    Step 3: Click on Add App and allow the storage permission it requires.
    upload_2019-5-19_20-23-8.png upload_2019-5-19_20-24-12.png upload_2019-5-19_20-25-7.png
    Step 4: Press the back button until you reach the VirtualXposed launcher screen and again click on launcher menu button, but this time, head over to Advanced Settings to Install / Uninstall Google Services
    Step 5: After installing the Google Services, press the back button until you reach the VirtualXposed launcher screen. Swipe up to access the Xposed Installer application.
    Step 6: Click on the hamburger icon or swipe towards right from the edge of the screen to access the Download section to download Xposed Installer modules.
    Step 7: Search for the module "DisableFlagSecure". Click on the module, download and install it.
    upload_2019-5-19_21-23-38.png upload_2019-5-19_21-22-53.png upload_2019-5-19_21-24-44.png
    Step 8: Click on Modules section by opening the menu of Xposed Installer same way as in Step 6 and tick the module installed.
    Step 9: In order to reboot the application, press back button until you reach the VirtualXposed launcher screen, and click on launcher menu button again, last option is Reboot, click on it.
    Steps 1 to 9 are to be followed just one time to configure everything needed to enable screen cast for apps like Hotstar, JioTV, Netflix etc.
    Step 10:
    Now, click on Add App and tick the app on which screen cast was not working and click on install and then VIRTUALXPOSED.
    upload_2019-5-19_20-23-8.png upload_2019-5-19_21-51-58.png upload_2019-5-19_21-56-38.png
    Step 11: After the apps are installed, you can access them by swiping up on the launcher screen.
    PS: If you get this type of screen when reopening VirtualXposed application, just deny it to save battery consumption.
    Congratulations, you have unlocked the abilities of Screen Cast back to normal as expected it to work on Smart TVs. See the screenshots below for proof.
    upload_2019-5-19_22-16-44.png upload_2019-5-19_22-17-12.png upload_2019-5-19_22-17-43.png
    If you have any problems/queries following this guide, feel free to reply on this thread.
    jaypambhar121 and Rakshit_Patil like this.
  2. Varun_Kathuria
    Cupcake Jun 5, 2019
    Varun_Kathuria , Jun 5, 2019 :
    Hi prabhat,
    Thanks for the useful link & information. After following the above steps, I am able to cast video now on jiotv, mxplayer, hotstar, Airtel TV. But Amazon prime, sonyliv & zee5 still not working.
    1) Amazon prime opens but does now show video
    2) zee5 opens & crashes
    3) sonyliv opens & then show black screen.
    If you have any suggestions for above then please help.
    Thanks
    Varun
  3. PrabhatNagpal
    Eclair Jun 5, 2019
    PrabhatNagpal , Jun 5, 2019 :
    Thanks for your valuable feedback. I'll check how to modify my workaround to work on the apps you mentioned for not working, and get back to you. Please like and share this blog, so that many people are helped.
    Varun_Kathuria likes this.
  4. Varun_Kathuria
    Cupcake Jun 5, 2019
    Sure I will share this link as OnePlus is not fixing there casting bug. Otherwise before I was using Moto g4 plus much low configuration & cheap but able to cast properly
    PrabhatNagpal likes this.
  5. PrabhatNagpal
    Eclair Jun 6, 2019
    PrabhatNagpal , Jun 6, 2019 :
    I tried to cast Prime Video and SonyLiv without VirtualXposed, they work normally.
    The only app which is not working is Zee5. I will try to figure out how to fix it too. But for now, try out Prime Video and SonyLiv casting normally.
  6. Varun_Kathuria
    Cupcake Jun 7, 2019
    Varun_Kathuria , Jun 7, 2019 :
    Have u tried in one plus 6t??
  7. PrabhatNagpal
    Eclair Jun 7, 2019
  8. Varun_Kathuria
    Cupcake Jun 7, 2019
    The issue is in one plus 6t. Now I have tried sonyliv it is working fine without exposed. But on amazon prime we can't see video
  9. Akhila Seetiraju
    Cupcake Jul 11, 2019
    Akhila Seetiraju , Jul 11, 2019 :
    I face the same issue with Netflix and I went through the steps but Netflix is not available in the Add app list in VirtualXposed. How to solve this for Netflix?
  10. PrabhatNagpal
    Eclair Jul 11, 2019
    PrabhatNagpal , Jul 11, 2019 :
    In my case, its coming. Just force close the VirtualXposed app and open it again.
  11. Akhila Seetiraju
  12. jaypambhar121
    Cupcake Nov 12, 2019
    jaypambhar121 , Nov 12, 2019 :
    i tried to oneplus 6t but xposed installer not open in step 5. i have 5 to 10 min wait but not open exposed installer. plesase suggest me..
  13. ruchikarawat
    Cupcake Nov 17, 2019
  14. gauravarora1983
    Cupcake Dec 23, 2019
  15. ManikandanSingaravel
    Cupcake Jan 30, 2020
  16. tarun2111
    Cupcake Mar 28, 2020 at 3:25 PM
    tarun2111 , Mar 28, 2020 at 3:25 PM :
    its not working kindly help .... i tried all the possible ways it shows "Playback does not support screen mirroring" while i tried to cast in samsung tv or any other tv the same error came rest the casting is working fine but when i tried to play any live video or any movie its show blank screen and the the same error
