5
Worse Battery Life than anticipated
  1. sidd_cfc
    Cupcake Nov 13, 2018
    sidd_cfc , Nov 13, 2018 :
    I m getting pretty good battery life .
    played a lot of PUBG , Asphalt 9 ,normal browsing etc and still 5:30/6 hrs SOT.
    Maybe you should try to calibrate your battery.
    if you are not playing any heavy games .. you should get around 7-8 hrs of SOT
    F_William_Su_HrLv likes this.
  2. Joshisameer
  3. HermesHidayat
    Gingerbread Nov 13, 2018
  4. V1541657065945
    V1541657065945 , Nov 13, 2018 :
    Hi I am using 6T for past two weeks. Based on my observation battery drains faster if I start browsing and using the phone. if I just use the phone for calling and viewing messages the battery stays fine. Also charging should be done in 30 mins. But mine is taking more than an hour to get completely charged. Please help me on the issues with resolution. thanks
  5. JelleZon
    OnePlus Accessory Tester Nov 13, 2018
  6. sprosa1
    Eclair Nov 15, 2018
    sprosa1 , Nov 15, 2018 :
    what are your settings like? adaptive battery? battery optimization? It seems like the battery is getting worse. lost 8% with 8 min SOT and 3 hours since last charge. this is with adaptive battery turned off as per some suggestions.
  7. Y1541397832093
    Cupcake Nov 15, 2018
  8. I1540990382415
  9. meirj25
    Eclair Nov 15, 2018
    meirj25 , Nov 15, 2018 :
    maybe Oneplus got a bad batch of batteries that's why many aren't getting 5+ hrs of SOT.
    Can you post where you're located?
  10. R1541265602481
    R1541265602481 , Nov 15, 2018 :
    There is definitely a battery issue, no doubt about it. I had a LG Stylo 3 plus prior to this phone and the battery life was better.
  11. JelleZon
    OnePlus Accessory Tester Nov 16, 2018
  12. Gepstra
    Gingerbread Nov 16, 2018
    Gepstra , Nov 16, 2018 :
    What you are describing is perfectly normal.
    It does not charge from 0-100 in 30 minutes. 1 hour is normal for a full charge.
  13. sprosa1
    Eclair Nov 16, 2018
    sprosa1 , Nov 16, 2018 :
    I'm in Canada
  14. Y1541397832093
    Cupcake Nov 18, 2018
  15. YasinArici99
  16. MarkoBatrac
    Ice Cream Sandwich Nov 18, 2018
