2
WORST BATTERY STANDBY
  1. anirudhkalyan19
    Gingerbread May 23, 2017
    anirudhkalyan19 , May 23, 2017 :
    I want to preface this post by saying that I had excellent battery life before but recently (yesterday) I saw the WORST battery life..... my phone went from 50 to 32 in 30mins and from 32 to 1 during the night! that is ridiculous!!!
    AKHILSABU45 and Siddhant3007 like this.
  2. Siddhant3007
    Donut May 23, 2017
    AKHILSABU45 likes this.
  3. adpro
    KitKat May 23, 2017
    adpro , May 23, 2017 :
    You should look for the app/process not letting your phone go into doze.
    Edit: Google services seems to be the culprit here.
    Clear data of google services from app settings.
  4. AKHILSABU45
    Cupcake May 23, 2017
  5. darius1988
    KitKat May 23, 2017
    darius1988 , May 23, 2017 :
    Have you installed same app in the last 2 days? if yess, than delete that app. Now clear cache and data from google play service, than clear cache from settings-store, than wipe cache from recovery.
  6. ninja123456
    Ice Cream Sandwich May 23, 2017
    Jagadeesh RK likes this.
  7. G_Ng_KWAN_YEIN_WUZo
    Eclair May 23, 2017
  8. MGreyWolf
    MGreyWolf , May 23, 2017 :
    mine is fine here. these are steps i did.
    1. clean install 4.1.3
    2. after i did the initial steps, i disabled all google apps, except play store.
    3. enable doze mode
    4. install all apps needed
    5. background data settings for all the apps which are no background data needed.
    6. silent all notifications for apps which you think no need for notifications.
    7. check all apps for battery optimization
    8. install greenify and do the settings you want
    9. clear data and cache for google play service (after clearing, do not close/back the window settings)
    10. restart to recovery and clear cache.
    11. done!
    btw, im using blackberry hub for emails substitute for gmail app.
  9. bart877ie
    Honeycomb May 23, 2017
    bart877ie , May 23, 2017 :
    howdy I am on 4.1.3 OP3T.
    battery life is awesome, I am getting 1.5 to 2 days with normal usage, this includes some showbox, Netflix, YT AMD social media.
    I never done clean installation just all from OTA's.
    There was a period that after 4.1.3 battery was draining noticeably quicker and after a week I done factory settings.
    Device is perfect ever since.
  10. Vishnu106
    Donut May 23, 2017
    Vishnu106 , May 23, 2017 :
    if u do all those settings then y we should take this mobile...
  11. MGreyWolf
    so you cant live without google apps? dont complain about you battery then.
    most google apps are battery eater and all of them have alternatives.
    i dont buy phone because i want to use google apps. ios doesn't have that.
    my phone work better without them (google apps).
  12. nen3i
    nen3i , May 23, 2017 :
    the culprit is not google services here. I had the same issue mobile radio active from google play services but in fact it was Facebook Messenger ! after i uninstalled it the draining was gone.
    so my advice for you it is to uninstall any Facebook app and see if you still have mobile radio active. if not then you have found the culprit. if you still do have this drain than it must be another chat app
    good luck
  13. MGreyWolf
    i have those apps both, and my battery is fine.
  14. nen3i
    it's only a thing about luck, not all are having problems with this apps some of us might have some of might not have. but it's worth a try to uninstall and reinstall
  15. anirudhkalyan19
    umm I tried clearing Google services does not work FYI I reset the phone thrice before clean Installing 4.0.2 and I do have some apps but the main culprit seems to be services especially backup
