8
Worst Camera quality after updates
  1. Priyanshu Sharma
    Jelly Bean Dec 9, 2018
    Priyanshu Sharma , Dec 9, 2018 :
    Disable HDR in settings and try shooting after HDR turned off, it will be fine after disabling. Try shooting same image with HDR turned on and HDR turned off, if you find any difference let us know.
    #41
  2. D1527531079366
    Froyo Dec 9, 2018
    D1527531079366 , Dec 9, 2018 :
    I am a professional photographer sir,I know how to use camera that's why I was able to spot difference between before update quality and after update quality.I always keep hdr on manual and use it only when I want that effect.
    #42
  3. Priyanshu Sharma
    No, I was just telling you because there are some flaws in HDR in new update and some users are having issues because of this so I asked you to check whether its because of this or anything else.
    #43
  4. D1527531079366
    Froyo Dec 9, 2018
    hmm no its not due to HDR,the overall experience has gone down since all these updates .
    #44
    mechengineer06 likes this.
  5. Rohitheats
    Donut Dec 9, 2018
    Rohitheats , Dec 9, 2018 :
    hold on this is perfect ?zoom in and I can see noise . One plus is doing over smoothening of pics.
    #45
  6. Sasikumar151984
    Cupcake Dec 9, 2018
    #46
  7. otto2
    Lollipop Dec 9, 2018
    otto2 , Dec 9, 2018 :
    No Software can help, if photographer is not able to follow simple rules.
    Show some sample. Pictures, in 2MB size, including Information about Device, OxygenOS Version, camera app Version, light Situation. Otherwise no one can help you with your issue.
    #47
  8. Priyanshu Sharma
    Jelly Bean Dec 10, 2018
    Priyanshu Sharma , Dec 10, 2018 :
    Its not a original pictures, the image is compressed.
    #48
  9. mechengineer06
    Eclair Dec 11, 2018
    mechengineer06 , Dec 11, 2018 :
    Thanks bro it worked
    #49
  10. mechengineer06
    Eclair Dec 11, 2018
    #50
  11. Ivan Zhekov
    Froyo Dec 11, 2018
    Ivan Zhekov , Dec 11, 2018 :
    The quality isn't much better compared to Pie. I downgraded to oreo to see the difference.. its the same, maybe the front facing camera is a little bit better but that's it. With the front facing camera HDR mode still sucks.
    #51
  12. lilsoul
    Donut Dec 11, 2018
    lilsoul , Dec 11, 2018 :
    It's better you tell customer service in your country.I did & was told it has been passed to the team in charge of updates & would be taken into consideration on the next update.I think it's better that way than reporting it here where nothing is really done about it.I think the more people report it to customer service the likelihood of them taking is seriously.
    #52
  13. B1544592758977
    Cupcake Dec 12, 2018
    B1544592758977 , Dec 12, 2018 :
    worst portrait mode quality after update.. actually android Oreo was better then android p..slow motion quality zero..I think OnePlus focusing on the OnePlus 6t only
    #53
  14. Vakil75
    Froyo Jan 3, 2019
    Vakil75 , Jan 3, 2019 :
    What for?
    #54
  15. sumantamca
    Gingerbread Jan 3, 2019
    sumantamca , Jan 3, 2019 :
    Even I was noticing the same on my OnePlus 6T, even OnePlus 3T is taking good picture in low light. Auto flash is not working properly.
    OnePlus 3T
    OnePlus 6T
    #55
