ramsuhas7 , via OnePlus 7 Pro , Dec 2, 2020 : Will OP 7 pro support WRAP 65 Charger, will their be any effect on battery?
superplus , Dec 3, 2020 : You've already received all of the information in the helpful replies from @Tokolozi, @J4t1np4r3kh and @Shailender Sharma, but I just wanted to add that all this information is also directly available on the product page itself (https://www.oneplus.com/product/oneplus-warp-charge-65-power-adapter):
Tokolozi , Dec 2, 2020 : Yes but only at the max charging speed of the OP7 Actual warp 65 needs additional hardware.
J4t1np4r3kh , via OnePlus 7 Pro , Dec 2, 2020 : You can use a WARP charger with the OnePlus 7Pro, however it will be capped at 30W charging. It will not charge quicker than that
Shailender Sharma , Dec 2, 2020 : Yes, It's fully backward-compatible too with previous OnePlus devices, offering Fast Charge speeds.
deepak2255 , via OnePlus Nord , Dec 3, 2020 : Wrap 65 need additional software and you can only charge you're oneplus 7 in 30t. You can use wrap65 at your own risk.
J4t1np4r3kh , via OnePlus 7 Pro , Dec 3, 2020 : This isn't a case of software, it's about the hardware lol. It's 65W because of the battery being split. And there isn't a risk of charging using the WARP charger. It's better not to say anything, than give false advice 🤷♂️
MoBruno , via OnePlus 7 Pro , Dec 3, 2020 : I don't think so , it can charge your op7 but max for 30w
Tokolozi , Dec 4, 2020 : No toting my own horn here, but the answer has already been given and marked as such. No need to repeat it each time.
superplus , Dec 4, 2020 : Yeah I'll close this thread, was waiting for an indication from @ramsuhas7 that their query had been resolved satisfactorily, but I'd say there's already more than enough answers by now. Question answered extensively, thread closed.
