Working Wrap charging not working via OnePlus Nord
  1. W1606884622749
    Cupcake Mar 2, 2021
  2. Gav_W86
    Moderator Moderator Mar 2, 2021
    Gav_W86 , Mar 2, 2021 :
    original charger and cable?
    charger and cable clean, clear of crud (including all plugs and sockets), and undamaged?
    on multiple power sockets?
    which OS version?
  3. ArchanaNarayanan
    Cupcake Mar 3, 2021
  4. Gav_W86
    Moderator Moderator Mar 3, 2021
    Gav_W86 , Mar 3, 2021 :
    the same questions asked in post 2 above apply to you then
  5. DARTHVADER25
    Gingerbread Mar 4, 2021
  6. Gav_W86
    Moderator Moderator Mar 4, 2021
    Gav_W86 , Mar 4, 2021 :
    maybe read the thread and answer the questions posed.
  7. D1600751934629
    Cupcake Mar 6, 2021
    D1600751934629 , via OnePlus Nord , Mar 6, 2021 :
    I am experiencing the same issue. Does anybody has any solution to this? As one of the solutions on found on other thread,I switched off the optimised charging as well but no luck! Please let me know if anybody has any solution for it.
  8. Gav_W86
    Moderator Moderator Mar 7, 2021
    Gav_W86 , Mar 7, 2021 :
    see post 2
  9. O1603547776361
    Cupcake Mar 17, 2021
    O1603547776361 , via OnePlus Nord , Mar 17, 2021 :
    I am.also facing same issue and mobile is getting heated with normal use only.
    Frustrated to see this frkm Oneplus. Please fix this ASAP.
    60mins 42% charge- skmething is seriously wrong.
  10. Gav_W86
    Moderator Moderator Mar 17, 2021
    Gav_W86 , Mar 17, 2021 :
    yet again in the thread I will point to the questions asked in post 2....
