Wrap charging not working via OnePlus 7 Pro
  1. Ashish_Sebastian_ , via OnePlus 7 Pro , May 8, 2021 :
    My OnePlus 7 pro just stopped wrap charging all of a sudden. It was working fine till yesterday and today when i tried to charge the device it shows charging instead of wrap charging. I tried it with my friends wrap charger and still it fails to fast charge my device. I even tried it in the safe mode. Both the charging pin and my phones charging port looks clean. My phone is currently running on oxygen os 11. Please help me with this.
  2. pablofg1978
    Head Moderator Head Moderator May 8, 2021
    pablofg1978 , May 8, 2021 :
    Check if you have optimized charging enabled, if you do, disable it
    Artemus. likes this.
  3. Ashish_Sebastian_ , via OnePlus 7 Pro , May 8, 2021 :
    But still it should show wrap charging right. Now it only showing charging. The wrap charging feature is not working and it takes a good amount of time to completely charge the device than before.
  4. pablofg1978
    Why don't you check what I suggest?
  5. #5
    pablofg1978 likes this.
  6. drl431
    Community Hero 2020 May 8, 2021
    drl431 , via OnePlus 6 , May 8, 2021 :
    Try cleaning out the usb-c connector on the phone. Use a toothpick or similar non-metallic probe. Look for pocket lint.
    Shailender Sharma and Artemus. like this.
  7. #7
  8. H1574777999411
    Cupcake May 11, 2021
    H1574777999411 , via OnePlus 7 Pro , May 11, 2021 :
    Facing the same issue from few days now. Cleaned/tried other 7 pro chargers too. It happened mostly after the new update I'm afraid. Nor disabling battery optimization worked.
  9. Ashish_Sebastian_ , via OnePlus 7 Pro , May 11, 2021 :
    Exactly. Even i faced this issue after the update. Did you try contacting the service center for the same?
  10. H1574777999411
    Hi there, I used a bit of rubbing alcohol and pin to clear my port. Was surprised to get out a good amount of waste from it and to my wonder the port started to work and do wrap charging.
    Ashish_Sebastian_ likes this.
