wrong left/right ballance oneplus 5
Did you notice any disbalance in audio via minijack?
  1. Yes, left louder
    60.0%
  2. Yes, right louder
    20.0%
  3. No
    0 vote(s)
    0.0%
  4. Im not sure, ill check and come back
    20.0%
  1. G_Mike_Fedotov_SXsb Eclair Sep 11, 2017
    G_Mike_Fedotov_SXsb, Sep 11, 2017 :
    Hi all! Having an issue with balance about 60/40 left/right using minijack (aux), tested different earpnoes, on different devices to compare, only OP5 has this problem.
    Is this a software bug, or hardware?
    equalizer, mono sound mode dont affect it, it still plays left louder than right.
    Anyone else is facing the same problem? mb it has a solution without root?
    Jasler likes this.
  2. felipemendes Ice Cream Sandwich Sep 11, 2017
    G_Mike_Fedotov_SXsb likes this.
  3. G_Mike_Fedotov_SXsb Eclair Sep 11, 2017
  4. felipemendes Ice Cream Sandwich Sep 12, 2017
    felipemendes, Sep 12, 2017 :
    Sorry, I was thinking about the inverted channels.
    I don't know what to do about your observation. Have you tried with different player apps?
  5. elanglois Lollipop Sep 12, 2017
  6. G_Mike_Fedotov_SXsb Eclair Sep 12, 2017
  7. elanglois Lollipop Sep 12, 2017
    elanglois, Sep 12, 2017 :
    PowerAmp. Best media player ever, and that particular shot is from the Beta.
  8. G_Mike_Fedotov_SXsb Eclair Sep 12, 2017
    G_Mike_Fedotov_SXsb, Sep 12, 2017 :
    Ill try out, but im pretty sure it works only in the app, not in whole system. (pls correct me if im wrong). Viper can definitly fix it, but the last thing i want to root is a 500$ device ,
  9. G_Mike_Fedotov_SXsb Eclair Sep 12, 2017
    just had a disbalance in reverce, right started playing much louder then left. after restat back to left louder. Hope its a software bug, fixed soon!(
  10. G_Mike_Fedotov_SXsb Eclair Sep 12, 2017
  11. elanglois Lollipop Sep 13, 2017
    elanglois, Sep 13, 2017 :
    Its app only, and what are you talking about? Not rooting a $500 device? Linux servers have the su command and some of them are $50,000. All rooting does is install the "su" command. It should be the first thing you do so that you can do proper data recovery if something goes wrong.
    And if you don't want root, you can just unroot after Viper is installed. It doesn't need it to process, just for installation
    Praty_28 and nobelium76 like this.
  12. G_Mike_Fedotov_SXsb Eclair Sep 13, 2017
    G_Mike_Fedotov_SXsb, Sep 13, 2017 :
    Thats correct, i meant i didnt expect fixing something so common as a sound ballance with a root, in this price category :(
    Praty_28 likes this.
  13. elanglois Lollipop Sep 13, 2017
    Balance on my 3T is fine
    And Viper has plenty of benefits.
  14. G_Mike_Fedotov_SXsb Eclair Sep 13, 2017
    Ok, i got root, viper, and the correct balance is the first bar. about 15-20 to the right. Oneplus has a huge one minus, imho. Earpnones are expected to work correct out of the box on any device. So check audio balance before u get it, if you can, but i hope im the one so lucky)
    And definitly expect it to be fixed in next updates :)
  15. PapaMooze Gingerbread Sep 13, 2017
  16. G_Mike_Fedotov_SXsb Eclair Sep 14, 2017
    G_Mike_Fedotov_SXsb, Sep 14, 2017 :
    update. Half of sounds dont exist on the right chanel. Compared same sennhisers cx 3.00, one pair to my old meizu, one to op5. right ear from op5, left from meizu, same song. Hi-hats and so on are clearly heard on the meizu right chanel, but dont exist on op5 right channel. both on mono mode. wtf?)
  17. G_Mike_Fedotov_SXsb Eclair Sep 15, 2017
    G_Mike_Fedotov_SXsb, Sep 15, 2017 :
    update. sometimes wnen plugging in the earphones google voice search turns on, even though my earphones dont have a mic. So im pretty sure its hardware problem.
  18. G_Mike_Fedotov_SXsb Eclair Sep 17, 2017
  19. v0 HaVoK 0v Ice Cream Sandwich Sep 17, 2017
    v0 HaVoK 0v, Sep 17, 2017 :
    So is this a problem with every OP5?
    If find it very hard to notice. Sounds like it could be a little louder on the left, but not sure if this is placebo from thinking about it too much.
    If it is, I think I've lost count of the bugs and problems with this device. Its actually quite a long list now... Most common thought since having this phone, well I hope it's at least just software and not hardware. But software or hardware there should not be this many bugs.
  20. G_Mike_Fedotov_SXsb Eclair Sep 17, 2017
    G_Mike_Fedotov_SXsb, Sep 17, 2017 :
    unfortunately in my case after comparing bluetooth and aux headphones im sure its not a placebo, cos with all thoughts about it bluetoth sounds strongly correct : ( Il wait couple days, for a feedback from support, or probably community solution, and then try to return the phone to my local shop, cos woth all benifits of op5 music is a 80% phone usage: )
