2
Wrong Password while decryption in Recovery mode ( OOS 10.3.1) via OnePlus 6
  1. sagarmgandhi
    Eclair Feb 25, 2020
    sagarmgandhi , via OnePlus 6 , Feb 25, 2020 :
    Hello,
    So i am on latest Oxygen OS update i.e. 10.3.1 and i installed it via OTA update.
    My device is fully stock and no rooting activity or similar stuff was ever performed.
    I usually at times Wipe Cache partition by going in recovery and using "Wipe Cache", but after the latest update i am unable to decrypt the device as it fails to accept the pattern password and keeps throwing "wrong password" error
    I have not even changed my pattern as well but i am really not sure why does it fail there.
    Any of you guys faced this similar issue ?
    it was all working fine earlier
    ( PS : I have also searched community and didn't find exact issue so created a new thread. )
    Thanks
    SG
    Kevindavy and W1547271965856 like this.
  2. DrJMun
    KitKat Feb 25, 2020
    DrJMun , Feb 25, 2020 :
    Factory reset? I know that'd result in a loss of all of your data, I don't know if you have a way of backing it up. I take it you cannot get into your phone at all?
    Have you tried any of the unbricking tools?
    Caoimhín likes this.
  3. F_Rishank_Gupta_QzKW
    Froyo Apr 10, 2020
    F_Rishank_Gupta_QzKW , Apr 10, 2020 :
    facing the exact same issue. I reached out to oneplus support, they said to reach out to google Android support as they can provide decrypt password.
    Unable to reach them. Did research on internet, unable to find solution.
  4. Artemus.
    Community Hero 2020 Apr 10, 2020
    Artemus. , Apr 10, 2020 :
    If you forget your password, you're pretty much screwed. In order to reset it, you need to reset your entire phone.
    Caoimhín and DrJMun like this.
  5. F_Rishank_Gupta_QzKW
    Froyo Apr 10, 2020
    i remember the password. i use my phone everday.
    the problem is with recovery mode. it does not accept normal password.
    borobro likes this.
  6. Artemus.
    Is it a pattern or PIN?
  7. F_Rishank_Gupta_QzKW
    Froyo Apr 10, 2020
  8. Artemus.
    Disable the password then.
  9. F_Rishank_Gupta_QzKW
    Froyo Apr 10, 2020
    already tried....does not work.
    i had work profile...removed that too... didn't work.
    disable admin control apps as well..... didn't work
  10. Artemus.
    Are you on 6 or 6T? (And is it a T-Mo 6T?)
  11. F_Rishank_Gupta_QzKW
    Froyo Apr 10, 2020
  12. Artemus.
    Wrong section. ;)
  13. F_Rishank_Gupta_QzKW
    Froyo Apr 10, 2020
  14. Artemus.
    Yes, but this is the 6/6T section.
  15. DrJMun
    KitKat Apr 11, 2020
    DrJMun , Apr 11, 2020 :
    You might have better luck at a response if you post this in 7T Pro forum since others may have the same problem.
    Artemus. likes this.
  16. Adithya_Harish
    Cupcake Aug 8, 2020
    Wellwisher80 likes this.
  17. Caoimhín
    OnePlus 9 Series Expert Community Expert Aug 8, 2020
    Caoimhín , via OnePlus 6T , Aug 8, 2020 :
    Remove all Screen Locks, Pin, Fingerprint and Facelocks etc
    Remove all Smart Locks as well.
    Reboot the phone, once rebooted, try going into recovery.
    See if it will allow without locks being set.
    You can setup your screen locks again once you are done.
  18. Wellwisher80
    Cupcake Aug 11, 2020
    Wellwisher80 , Aug 11, 2020 :
    I did the latest OnePlus 6 upgrade Sunday. Last night my phone gave an wrong password message and I haven't changed the password. I tried to enter my password in the recovery mode but it still won't take it. I don't want to reset my phone (no backup app.) Help!!!
  19. Wellwisher80
    How do you remove the all smart locks?
  20. Caoimhín
    OnePlus 9 Series Expert Community Expert Aug 11, 2020
    Caoimhín , via OnePlus 6T , Aug 11, 2020 :
    In Settings, Security & Lock Screen, Smart Locks. If you have any setup, remove them.
