[Submitted] Wrong time zone settings for Chile.
  1. Adidz
    Gingerbread Aug 19, 2019
    Adidz , Aug 19, 2019 :
    Chile timezone for Santiago is selected. The timezone should be utc -4 but its showing up as utc -3 in system settings. Causing the time to jump 1 hour ahead. This started from August 1st week. Same across all oneplus devices. Daylight savings start from September 8 in chile but it seems it has started 1 month before in oneplus clocks.
    Y1546139495530 likes this.
  2. Adidz
    I know the workaround is to set the time manually. But i have some applications which rely on accurate time which don't work if i set time manually or select wrong timezone.
  3. Y1546139495530
    Cupcake Aug 21, 2019
  4. Y1546139495530
