9
WugFresh's Bacon Root Toolkit(BRT)
  1. rmsalihdeen
    Eclair Jan 22, 2016
    rmsalihdeen , Jan 22, 2016 :
    I am trying to use BRT but I couldn't find the Google Drivers after installing it. My Device Manager shows only "ABD Interface" as not installed and when I tried to update that driver, I got a bunch of drivers from Samsung and Google Inc was no where to be seen. Is there a workaround ?? I've absolutely followed all the steps. I can't find "Android Device" in the list of drivers. Please help.
  2. rmsalihdeen
    Eclair Jan 22, 2016
    This is exactly my problem
  3. davidc18
    Cupcake Feb 6, 2016
    davidc18 , Feb 6, 2016 :
    Same problem as the A0001 is only recognized as an ADB device and the process stops there.
  4. fanatik85
    Gingerbread Feb 14, 2016
  5. funkyzebra
    Cupcake Mar 9, 2016
    funkyzebra , Mar 9, 2016 :
    I don't know if this thread is still being followed. But my issue pertains to the driver setup. Whenever I uninstall and try and re install drivers, my computer sees it as a portable device and loads a totally separate driver for it. I don't know where the rootkit installs the google drivers so I can select them. Device manager.PNG Driver install.PNG Driver Properties A0001.PNG
  6. valdoaloquio
    Froyo Apr 12, 2016
    samrendra likes this.
  7. kryshnakishore
    Ice Cream Sandwich Apr 23, 2016
  8. Synchronous
    Cupcake May 6, 2016
    Synchronous , May 6, 2016 :
    can i use this toolkit to flash stock cos 12.1 and subsequently upgrade to cos 13?
  9. Gonzo01
    Lollipop May 6, 2016
    Gonzo01 , May 6, 2016 :
    yes
  10. marios_ch
    Cupcake May 10, 2016
    marios_ch , May 10, 2016 :
    can i use this tool to go completely stock? version 12?
    i am with a custom rom now and stock recovery
    thanks
  11. MikeHFM
    Cupcake May 17, 2016
  12. Gry1503
    Cupcake May 18, 2016
    Gry1503 , May 18, 2016 :
    this is a great tool. I am a beginner at rooting and flashing recoveries and stuff like that. This proved to be such great help.!!!
  13. amankarer
    Cupcake May 25, 2016
    amankarer , May 25, 2016 :
    Hey there is a problem in unrooting my OPO .
    In the drivers installation steps every thing is going right but in the last step it is not showing the prompt "computers unique RSA fingerprint " .
  14. bklyn000
    Gingerbread Apr 14, 2017
    bklyn000 , Apr 14, 2017 :
    Hi, I just used this toolkit and installed the drivers smoothly, now I want to make a backup before unlocking bootloader but everytime I backup afterwardsit says zero 0mb, it didn't back anything up. Any ideas? I turned airplane mode on like it says to do but nothing, it's the same. I have a OnePlus One. Thanks
  15. MaximChicu
    Gingerbread Nov 5, 2017
