Y series : HDMI PORT 2 Audio output issue via OnePlus 3T
  1. pkstkk
    Cupcake Jan 4, 2021
    pkstkk , via OnePlus 3T , Jan 4, 2021 :
    Hi, I am using 43Y series TV. I have been Using HDMI 1 (ARC) port for DTH connection and working ok for audio and video.. But Now i am trying to connect HDMI port 2(down side) for dth connection, Video is working. But audio output is not coming from TV. I have tried new cable also. Again i tried HDMI 1 port and working.. again tried HDMI port 2. But it is not working audio. But during connection time i have Once removed HDMI cable and re connect then audio is ok.. I can't remove and connect every time.. So kindly solve the issue.... Thank you...
  2. Tokolozi
    Most Original Avatar Jan 4, 2021
    Venky61 likes this.
  3. pkstkk
    Cupcake Jan 4, 2021
    No.. I have not connected ARC HDMI... It is free..
  4. Venky61
    OnePlus TV Expert Community Expert Jan 4, 2021
    Venky61 , Jan 4, 2021 :
    Hii...
    Can you provide more details,
    Which Set-top box are you using?
    Does it support Dolby Audio? If yes, what have you selected in Sound<Digital Out settings of the TV.
    Actually, I face a similar situation with my desktop.
  5. pkstkk
    Cupcake Jan 4, 2021
    DTH is Airtel
    Yes. Dolby support
    I have selected dolby digital
  6. Venky61
    Ok... Try using Sound<Digital Out as PCM and check if you still face the issue. It's not a solution, but just to understand the root cause.
    Tokolozi likes this.
  7. pkstkk
    Cupcake Jan 4, 2021
  8. Tokolozi
    Tokolozi , Jan 4, 2021 :
    Windows audio drivers are sometimes F'ed up. But don't think that's the case here when it's a STB.
  9. pkstkk
    Cupcake Jan 4, 2021
    Ok.. But HDMI 1 port is working fine for same setting..
    How is working audio output once remove and connect?
  10. Venky61
    Ha ha... True.... But it happens to me with only one of the TV I have, all other settings being the same.
    HDMI 2 surely seems to have issue on Y series as there are other users who reported the same and they were using Airtel DTH only. That's the reason I think it has to do with the Dolby processing through that port.
    If you have a laptop, connect it to HDMI 2 and see if you face the same issue.
    References
    https://forums.oneplus.com/threads/open-hdmi-ports-issue-43y1.1291776/#post-22261120
    https://forums.oneplus.com/threads/hdmi2-port-sound-issue-in-43y1.1334240/#post-22306397
  11. pkstkk
    Cupcake Jan 4, 2021
    Ok.. I will check and update... Thank you
  12. Venky61
    OnePlus TV Expert Community Expert Jan 6, 2021
    Venky61 , Jan 6, 2021 :
    Hey... Did you check?
  13. pkstkk
    Cupcake Jan 6, 2021
    pkstkk , via OnePlus 3T , Jan 6, 2021 :
    Hi, i am out of home and will be reach this week end...i will update once reached...
    Venky61 likes this.
  14. pkstkk
    Cupcake Jan 8, 2021
  15. pkstkk
    Cupcake Jan 10, 2021
  16. Venky61
    OnePlus TV Expert Community Expert Jan 11, 2021
    Venky61 , Jan 11, 2021 :
    Hey,
    Not sure then what could be the issue. Maybe there's a software bug that's leading to it. The last resort can be to do a full reset of the TV and check or wait for an update hoping that it will be solved.
    PS: Did you try with a laptop, is it happening the same?
  17. pkstkk
    Cupcake Jan 11, 2021
    pkstkk , via OnePlus 3T , Jan 11, 2021 :
    Yes.. I tried at laptop...
    Power on tv during Laptop connection. Please find below points...
    1. NO signal screen is coming during connection
    2 then remove and connect HDMI cable then video is coming. Audio has not come. Then select audio track for One plus Tv and audio is coming..
    3. I am trying same setting again. But audio is not coming during with OnePlus Tv audio track mode... But again re select oneplus tv audio track and ok...
