Yellow Tint
Does the yellow tint problem still occur for you?
  1. Yes
    54.7%
  2. No
    41.5%
  3. I don't know.
    3.8%
  1. Hjalpmovie
    Gingerbread Jun 3, 2015
    Hjalpmovie , Jun 3, 2015 :
    I once had this problem and turning off sunlight enhancement fixed it.
    addam and triviums like this.
  2. triviums
    triviums , Jun 3, 2015 :
    Aren't both colour enhancement and sunlight enhancement new additions to cyanogen? Since the yellow tint happened in CM11s as well, wouldn't turning them off not change a thing? I will try turning them off and see if that fixes it, but I doubt it's the issue here since I think they weren't on CM11s
  3. dsmonteiro
    Community Consultant Jun 3, 2015
    dsmonteiro , Jun 3, 2015 :
    No, it has been around for awhile, I believe.
    addam likes this.
  4. Hjalpmovie
    They were there, I had those settings since 44s.
  5. mwayner
    Lollipop Jun 3, 2015
    mwayner , Jun 3, 2015 :
    Sunlight enhancement being enabled does cause the yellow tint, I've observed. Doesn't bother me though.
  6. LifelessLewis
    Jelly Bean Jun 3, 2015
    LifelessLewis , Jun 3, 2015 :
    Worth a try yeah, but it might not solve it. I'm not sure what to do if it doesn't work sorry :(
  7. John j
  8. addam
    KitKat Jun 3, 2015
    addam , Jun 3, 2015 :
    I would turn off your display enhancements as everyone else has stated. I hope that works for ya.:)
  9. triviums
    Oh, ok my mistake then... I will turn off sunlight enhacement then, but I won't be able to tell if it has worked or not since I don't know how to make the yellow tint happen on command... thanks for helping :)
    addam, LifelessLewis and dsmonteiro like this.
  10. dsmonteiro
    Don't worry. Just let me know once you are sure... ;)
    addam likes this.
  11. Abby244
    Eclair Jul 28, 2015
    Abby244 , Jul 28, 2015 :
    I bought my opo in January .
    It had yellow tint at the bottom of the screen. Went through many threads . Tried many solutions, nothing changed. Waited for this much long to let it go on its own , but still no improvement.
    Any kind of suggestions or ideas are welcomed.
    Should I start troubling customer care ?
    What if it is also there on OP2?
  12. Me1256
    KitKat Jul 28, 2015
    Me1256 , Jul 28, 2015 :
    There are ways to color calibrate the screen, so it offsets the yellow, making your screen look normal. Other than that, there isn't much I can say.
    Nyco30 likes this.
  13. Abby244
    Eclair Jul 28, 2015
  14. Nyco30
    Ice Cream Sandwich Jul 28, 2015
    Nyco30 , Jul 28, 2015 :
    No: we either solved the issue by adjusting colour schemes (one post on the forum giving the exact figure for optimal solution) or using ultraviolet solution (but that's more old school...But worked for me - check review for haters in my signature).
  15. jay ray
    Ice Cream Sandwich Jul 29, 2015
    ogriff likes this.
  16. GetDynamic
    Honeycomb Jul 29, 2015
    sharolynvicente likes this.
  17. Diizane
    Gingerbread Jul 29, 2015
    Maquuuu likes this.
  18. MrIanB
    Jelly Bean Jul 29, 2015
    jay ray and rphlfjrd like this.
  19. FAQBytes
    FAQBytes , Jul 29, 2015 :
    I do remember it and mine had a minor yellow tint. Not nearly as bad as some though.
    ariefun123, jnmaster and Lunatasian like this.
  20. Kenny_B
