12
YOG4PAS3JL is great! Thank cyanogenmod, I like COS (CM12.1 S)
  1. Deactivated User
    Nov 9, 2015
  2. LiberationHD
    Froyo Nov 9, 2015
  3. samppa79
    Cupcake Nov 9, 2015
  4. osaz_oe
    Honeycomb Nov 9, 2015
    osaz_oe , Nov 9, 2015 :
    Can anyone say if the themes bug has been fixed? The one where if you install a font apk it's not recognised?
  5. Ulstrand
    Donut Nov 10, 2015
    Ulstrand , Nov 10, 2015 :
    Sorry.... It is the update before YOG4PAS3JL
    I mean it was Yog4pas2sl, but i am not sure.
    anyways.... Is it possible to download YOg4pas3jl and install it if you don´t have the latest update?
    As you can see, I´m not programmer or wizard. and my knowless og Cyanogen is rather light.. :confused:
    But instead of starting installing an outdatet version, maybe there was a way to get the latest update.. just thinking...
  6. Ulstrand
    Donut Nov 10, 2015
    Thank You very much..
    I get it. I will try.
    Have a nice day. :D
  7. ouyamaster
    Honeycomb Nov 10, 2015
    ouyamaster , Nov 10, 2015 :
    Try gservice fix and babysit power save make sure it stays in power save.
  8. xilvia
    Froyo Nov 11, 2015
    xilvia , Nov 11, 2015 :
    same battery drain iusse after update - 2 days ago
    here my battery data:
    Android System 11 %
    screen 3 %
    Android OS 2%
    wifi 1%
    before update the screen was at first place.
  9. Kiran131993
    Cupcake Nov 13, 2015
  10. silent785
  11. Davo57
    Davo57 , Nov 13, 2015 :
    Is the google dialer hack working on yog4pas3jl for anybody? I've read it does and it doesn't. Can't wait to get rid of this crap nextdialer.
  12. sparkyplus
    Gingerbread Nov 20, 2015
  13. FFC
    Gingerbread Dec 3, 2015
    FFC , Dec 3, 2015 :
    I could not install any third parties apps when I upgrade to CM12.1-YOG4PAS3JL and I already tick the box of "unknown source of third parties", how can I solve this problem? f
    Is it all date will lost if I downgrade to lower version of CM?
  14. F4T3
    Cupcake Dec 3, 2015
    F4T3 , Dec 3, 2015 :
    Is it truly worth the upgrade? I'm kinda worried after screwing around with my OPO nearly the whole day ...
    After 3 weeks it was finally delivered. To my disappointment it came with OxygenOS 1.0. So I instantly rooted the thing and flashed a custom recovery. Then I applied CM 12.0 ... And now it's presenting me the update 12.1.
    What shall I do? Will it apply the update automatically or will it DL it and I have to wipe cache and install from zip in custom recovery? Is it even worth it for that matter?
