You are offline. error proxy conection on 4g Lte
  1. nft
    Eclair Jan 24, 2017
    nft , Jan 24, 2017 :
    Oxygen OS 4.0.2. OP3... When i try to go to any webpage, using Chrome, i get message You are ofline, error proxy conection. After i refresh a page a couple a times it opens normaly. this is hapening only on mobile network.. wifi is ok. Does Enyone else have a same issue or some solution?
  2. abu_kado
    Cupcake Jan 24, 2017
    abu_kado , Jan 24, 2017 :
    im getting slow 4g connection.. which is not normal in my area.. i usually got 30mbps.. but afyer the update got 2mbps max [e]1f622[/e]
  3. dinjesk
    KitKat Jan 24, 2017
    dinjesk , Jan 24, 2017 :
    have u tried checking if the APN settings are still correct according to your carrier?
  4. abu_kado
  5. amitabh.das
  6. scottx2010x
