YouTube battery drain
  1. Samwiise
    Honeycomb Mar 7, 2018
    Samwiise , Mar 7, 2018 :
    Hello anyone noticed that YT start facing huge battery drain issues it's in the top off the list over screen and Android system idk if it's a bug in the app or it's in Oreo update, i updated recently and don't have this issue in 4.5.1 Nougat.
  2. Auristic
    Lollipop Mar 7, 2018
  3. NeVeR_SeTTLe
    The Lab - OnePlus 6 Reviewer Mar 7, 2018
    NeVeR_SeTTLe , Mar 7, 2018 :
    Well what do you expect? YouTube is a battery hog because your watching movies (sometimes in FHD). Battery uses screen and GPU so it is going to drain more battery.
    bojantomic likes this.
  4. Samwiise
    But in nougat i never noticed this issue in hours of watching, and i watch only in 480p.
  5. Samwiise
    are you sure of that?
  6. Auristic
  7. NeVeR_SeTTLe
  8. Samwiise
    Ok so at this moment the solution is to stop watching youtube in Oreo.
  9. Auristic
  10. Auristic
  11. Samwiise
    Already Donne, the issue persist Can you post a screenshot of consumption if you use Youtube.
  12. NeVeR_SeTTLe
  13. NeVeR_SeTTLe
    Oreo is a little heavier than Nougat. You do realize that? Wiping cache and also some tips to prolong battery life work, but YouTube will drain the battery no matter what. You can also try some alternative apps instead of YouTube. Some apps are lighter version of the YouTube app.
    Auristic likes this.
  14. Auristic
    Auristic , Mar 7, 2018 :
    If you've already wiped cache to no avail or reset your device to factory default or tried using another app...
  15. Samwiise
    But the question is why on Nougat Youtube worked like a charm :(
  16. Auristic
    The main battery draining services and apps are Google and Facebook 's...
  17. NeVeR_SeTTLe
    What is not working in YouTube in Oreo?
  18. adil_911_
    Froyo Mar 7, 2018
  19. NeVeR_SeTTLe
    Yes, but they are optimized either way. The Google Play Services and Facebook and other social media apps are the culprit. The social media apps are poorly coded and so the battery drain persists. Google Play Services always runs in the background and sometimes it is hard to stop it unless you root and install Custom ROM.
  20. Samwiise
    All works fine except the battery drain, in nougat youtube never reached over 10% of total battery life, now in Oreo it's more than 25%.
