Zen Mode Does not work after one use i Oneplus 3T
  1. G_Areeb_Qureshi_jGfT Eclair Jun 18, 2019
    G_Areeb_Qureshi_jGfT, Jun 18, 2019 :
    After the New Android Pie Update
    we finally got the Zen Mode for Oneplus 3T
    so i tried using it
    i was able to use it only once
    as you can seen in the screen shots
    there was a start button when ZenMode was used for 0 times
    but after once use The Start button vanished
    there are only two ways to be able to use it more than once
    first by Uninstalling it and then reinstalling it
    second after Completing one session zenmode asks whether you want to go again and there was a start button
    but after that there was no start button so i was unable to use zen mode
    even if i click on the Zen mode iCon provided in the Status bar
    it would only open this
    and not actually activate zen mode
    i have already seen another thread regarding this problem but it wasn't answered and Closed
    i would ask you guys to properly look into the matter and then Close this thread again
  2. ghostofcain Marshmallow Jun 18, 2019
    ghostofcain, Jun 18, 2019 :
    Something wrong with the existing threads? Zen mode is not officially supported by OP3(T)
    B_Wrath likes this.
  3. G_Areeb_Qureshi_jGfT Eclair Jun 18, 2019
    I dont know about that But After i Updated to Android Pie It already had Zen Mode
  4. ghostofcain Marshmallow Jun 18, 2019
    Oh, I wasn't aware of that.
  5. harshit.b Ice Cream Sandwich Jun 18, 2019
    harshit.b, Jun 18, 2019 :
    Are you sure you didn't install an apk?
    ghostofcain likes this.
  6. G_Areeb_Qureshi_jGfT Eclair Jun 18, 2019
  7. B_Wrath Marshmallow Jun 18, 2019
    B_Wrath, Jun 18, 2019 :
    I don't have zen mode automatically on pie. How did you get?
    That is the version number?
  8. G_Areeb_Qureshi_jGfT Eclair Jun 18, 2019
    search for Zen mode in settings ,or in the status bar click the edit option you may find a new icon for zen mode
  9. B_Wrath Marshmallow Jun 18, 2019
    I have already tried that.
  10. G_Areeb_Qureshi_jGfT Eclair Jun 18, 2019
  11. B_Wrath Marshmallow Jun 18, 2019
  12. G_Areeb_Qureshi_jGfT Eclair Jun 18, 2019
  13. KeepTransisting The Lab - OnePlus 7 Pro Reviewer Jun 18, 2019
    KeepTransisting, Jun 18, 2019 :
    The fact that it says "Uninstall" and not "Disable" means it was not installed as part of the system and it was installed separate. At this moment, Zen Mode is not compatible with the 3 / 3T, and it probably won't be, in all honesty.
  14. B_Wrath Marshmallow Jun 18, 2019
  15. B_Wrath Marshmallow Jun 18, 2019
    Was about to say this after getting the full page screenshot. Guys think we are stupid.
  16. G_Areeb_Qureshi_jGfT Eclair Jun 18, 2019
    when i first d
    updated my phone i got the zen mode but since it wasn't working after one time , i uninstalled it and downloaded apk . .
  17. B_Wrath Marshmallow Jun 18, 2019
    You cannot Uninstall a system app!
  18. KeepTransisting The Lab - OnePlus 7 Pro Reviewer Jun 18, 2019
    Well, it's not compatible with the 3 / 3T, so uninstall it. And no, Zen mode was never available via update for the 3/ 3T. They might add it in the future, but I wouldn't bet on it.
    If you really wanted, you could implement your own Zen mode by putting your phone down and walking away.
