Zenfone 2 battery drain culprit - Android OS
  1. marcyeo Ice Cream Sandwich May 28, 2015
    marcyeo, May 28, 2015 :
    have been using zenfone 2 4gb ram version for almost 3 weeks now. every is great except for battery drain faster than it should be. android os using battery more than usual for this phone. anyway i can overcome this while waiting for firmware update? thanks guys
  2. dustbunnyck Jelly Bean May 28, 2015
    dustbunnyck, May 28, 2015 :
    Sounds like the same lollipop problem that everything that's on lollipop has issue with
    alexlam24 and Lingering like this.
  3. marcyeo Ice Cream Sandwich May 28, 2015
    Ceasedd likes this.
  4. dsmonteiro Community Consultant Community Expert May 28, 2015
    dsmonteiro, May 28, 2015 :
    I'd say that the fact that Atom is a x86 processor is the real issue there.
  5. marcyeo Ice Cream Sandwich May 28, 2015
    obviously it is a software issue man, right?
  6. frigginjoe Froyo May 28, 2015
    frigginjoe, May 28, 2015 :
    If Android OS is hogging up the battery time, I can't see how that's hardware.
    Stuff's running. Their distro needs to be tuned up.
    Last night I rolled back to KitKat and went from 88% to 46% battery on my OPO myself, found Android OS ate my power. On the same phone that had great battery like life the previous day (but lots of google annoyances).
    I would like to see something close to an ideal environment battery test vs Snapdragon for actual hardware battery drain.
  7. dsmonteiro Community Consultant Community Expert May 28, 2015
    Android is well tested and developed for ARM. x86? Not so much.
    So yeah, it's a software issue but that derives from hardware.
    merewoodbebox, iJuli-N and teckboy30 like this.
  8. caldrich Jelly Bean May 28, 2015
  9. marcyeo Ice Cream Sandwich May 28, 2015
    ic..so any solutions for this? :)
    Ceasedd likes this.
  10. dsmonteiro Community Consultant Community Expert May 28, 2015
    Don't buy x86 devices... :p
    Seriously though, I bet they will address it in future updates. You can try and check if there are any wakelocks and then search online for possible fixes.
    Also, you can have a look at XDA and see if anyone else is complaining about the same.
  11. petrosbrzs Gingerbread May 28, 2015
    petrosbrzs, May 28, 2015 :
    dont worry. android 5.0 lollipop had an issue with the battery, this is fixed in 5.0.1, but that update isn't out yet for the zenphone 2
  12. marcyeo Ice Cream Sandwich May 28, 2015
    intel atom really runs well in z2...just software from asus is terrible..sigh
  13. dsmonteiro Community Consultant Community Expert May 28, 2015
    Z2?
    Yup, also not very fond of Asus smartphones
  14. Rob W Ice Cream Sandwich Community Expert May 28, 2015
    Rob W, May 28, 2015 :
    It's a software issue. It's the Android OS drain problem. It'll be fixed in the next version update.
    Also, ZenFone 2 is amazing so far. I've had it since the NYC launch event, and I have very few complaints.
    Don't worry, the bug will be gone soon. ;)
    benluca and dsmonteiro like this.
  15. rikardo1979 Lollipop Community Expert May 28, 2015
  16. WolfpackN64 Jelly Bean May 28, 2015
    its_gallenn likes this.
  17. frigginjoe Froyo May 28, 2015
    What is this based on?
    Given the fact this battery drain is a known and ongoing issue on existing Snapdragon and even Mediatek hardware I'd say unless you have some insight on the layer between Android and the chipset this doesn't hold much water.
  18. jmschuit Cupcake May 28, 2015
  19. chvzedgar Ice Cream Sandwich May 28, 2015
    chvzedgar, May 28, 2015 :
    It's good that you ask, and I don't blame you for that. But I think you are more likely to get answers at your device's dedicated forums or at XDA
    Ceasedd likes this.
  20. Rob W Ice Cream Sandwich Community Expert May 28, 2015
    Please cite sources for this. As far as I can tell, you are expressing a personal opinion/bias against the Intel chipset and blaming the problem on that.
    Battery drain on 5.0 is a known issue that impacted the OS, not based on the hardware that was supporting it.
